Focus locks
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=88714
Printed Date: June 09, 2024 at 6:45 PM
Topic: Focus locks
Posted By: Hymer
Subject: Focus locks
Date Posted: January 10, 2007 at 1:06 PM
Do the factory remotes work if the vehicle is under rs? Just did a 903 astro [no keyless] , and apperantly the fobs don't work if the car is running. Like the stupid hondas?
------------- Tire Proz Stillwater Mn
High End Restyling and Comlete Repair
Posted By: customak47
Date Posted: January 10, 2007 at 3:52 PM
did you hook up keysense? if so, try disconnecting and see if they work... ------------- My rifle is my friend...
Posted By: Hymer
Date Posted: January 10, 2007 at 4:38 PM
Nope, no keysense, this rs has no keyless on it. so you use the factory key fob for lock and unlock. I think it's probably like the hondas, key fob dont work when the car is running...
Posted By: ers1121
Date Posted: January 10, 2007 at 5:29 PM
The Fords do not work if the car s running.
------------- Ed
Posted By: Chris Luongo
Date Posted: January 10, 2007 at 5:48 PM
No, it doesn't work with the car running. Why not just sell the customer one that does locks and trunk?
On the older-style Focus, the factory keyless module is up above the glove box, and if you find the ignition wire and interrupt it during remote start, the keyless will work..........but that takes more time and labor than just connecting the three wires for locks/trunk.
Posted By: KarTuneMan
Date Posted: January 10, 2007 at 6:20 PM
find the ignition wire and interrupt it during remote start, Use a relay, "open" the wire with ground while running.....not too tuff. -------------
Posted By: Mike M2
Date Posted: January 10, 2007 at 8:33 PM
Actually, Fords do work while running, just not the Mazda body cars like the Focus... ------------- Mike M2
Tech Manager
CS Dealer Services
Posted By: Mike M2
Date Posted: January 10, 2007 at 8:36 PM
Most RS have an igntion out that is already interupted during RS( most DEI and AVOX at least) ------------- Mike M2
Tech Manager
CS Dealer Services
Posted By: Hymer
Date Posted: January 10, 2007 at 8:37 PM
Thats what I figured, Ill probably just add keyless onto the 903, just never really noticed before.. most of my astros are 2106 or 2205 models.... with keyless... Thanks guys...
