tach wire, 1999 ford f150 4x4
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=88935
Printed Date: April 12, 2026 at 12:45 PM
Topic: tach wire, 1999 ford f150 4x4
Posted By: slammed84s10
Subject: tach wire, 1999 ford f150 4x4
Date Posted: January 14, 2007 at 6:45 PM
I am having problems finding the tach wire on my 1999 ford f150. I have a hornet alarm and am trying to put in a remote start. The vehicle wiring on here says pin 48 at the bcm but there is no pin 48 on my truck.
Posted By: KarTuneMan
Date Posted: January 14, 2007 at 7:22 PM
 TACH SIGNAL Pink/white At Ignition coil   AC
 On the 4.2L engine, this wire provides a 2 cylinder signal. For 4.6 Triton tach is PINK/WHITE at driver's side coil, on 5.4 Triton it's WHITE/ PINK at harness through firewall on driver's side. For the V10 engine, use the negative side of any of the 10 injectors on the top of the engine.
Posted By: chris354
Date Posted: January 14, 2007 at 7:45 PM
I would just use one of the injector wires. I believe it will be the wire thats not red, but just check and use the wire thats not common at each injector. It the only source that will work reliably with DEI rs on Fords.
