2002 Mitsubishi Galant
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=8924
Printed Date: May 03, 2024 at 8:08 AM
Topic: 2002 Mitsubishi Galant
Posted By: accent
Subject: 2002 Mitsubishi Galant
Date Posted: February 01, 2003 at 12:35 PM
Need a wiring diagram for a 2002 Galant if anyone has one, thanks
Posted By: jayts95
Date Posted: February 01, 2003 at 6:55 PM
|              12V|blue / YELLOW         |+  |ignition harness            |
|          STARTER|BLACK / YELLOW        |+  |ignition harness            |
|         IGNITION|BLACK/ white         |+  |ignition harness            |
|        ACCESSORY|blue/red            |+  |ignition harness            |
| SECOND ACCESSORY|blue/black          |+  |ignition harness            |
|       POWER LOCK|purple              |-  |either kick panel or *1     |
|     POWER UNLOCK|lt. GREEN/ red       |-  |either kick panel or *1     |
|       LOCK MOTOR|blue/red            |   |drivers kick panel          |
|     UNLOCK MOTOR|blue/black          |   |drivers kick panel          |
|    DISARM DEFEAT|blue/orange         |   |passenger kick panel        |
| PARKING LIGHTS +|GREEN / WHITE         |   |at the fuse box             |
| PARKING LIGHTS -|                    |   |                            |
|       HEADLIGHTS|                    |   |                            |
|     DOOR TRIGGER|GREEN/ orange        |-  |top front of the fuse box   |
| DOME SUPERVISION|                    |   |                            |
|  TRUNK/HATCH PIN|white               |-  |at light in the trunk       |
|         HOOD PIN|blue/black          |-  |underdash fuse box          |
|TRNK/HTCH RELEASE|                    |   |                            |
|  FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|red *4              |-  |drivers door harness        |
| DISARM NO UNLOCK|                    |   |                            |
|       TACHOMETER|white               |   |instrument cluster or *2    |
|      SPEED SENSE|yellow/black        |   |instrument cluster or radio |
|       BRAKE WIRE|green               |+  |brake pedal switch          |
|     HORN TRIGGER|GREEN / WHITE         |+  |*3                          |
|           WIPERS|blu/red, blu/org    |+  |wiper motor                 |
|  LF WINDOW UP/DN|RED / blk - grn/blk   |A  |drivers door switch         |
|  RF WINDOW UP/DN|RED / wht - grn/wht   |A  |drivers kick panel          |
|  LR WINDOW UP/DN|green - yellow      |A  |drivers kick panel          |
|  RR WINDOW UP/DN|orange - grn/yel    |A  |drivers kick panel          |
Notes:
NOTE: Some models have an immobilizer system that needs to be bypassed during remote start.  Use DEI module 555U to bypass.  *1 The door lock wires are in a black plug behind the fuse box, above a green module.  *2 On the 6 cylinder models, the white tach wire can also be found at the distributor. On the 4 cylinder models, the tach wire can also be found at the ignition failure sensor on the intake manifold, the white wire is in a 4 pin plug with three BLACK/ stripe wires.  *3 Horn relay in engine compartment relay box, or also found right at horn behind left side of front bumper.  *4 When doing remote start on vehicles with factory alarm, must also interrupt the blue/red (-) key sense wire at the steering column using the status output wire to bypass the factory starter kill.
