2000 Acura Integra trunk pin
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=89246
Printed Date: June 08, 2024 at 5:15 AM
Topic: 2000 Acura Integra trunk pin
Posted By: f00dstamps
Subject: 2000 Acura Integra trunk pin
Date Posted: January 20, 2007 at 8:11 AM
Hey All,
I'm having trouble finding the trunk pin wire. I know it's supposed to be a green with silver dots in the driver's kick but I cannot find it. I'm testing the same bundle of wires that I got the lock and unlock wires from. I've tested every single green wire in that bundle and have also temporarily hooked up the wire from the alarm. I also found a post that says you can also use the green wire in the blue 12pin plug that is located above the fuse box. This wire did not work either. Can someone give me more specific directions on where to get this wire?
I don't think it should matter but this is a Type-R. Thanks.
Posted By: profuse007
Date Posted: January 20, 2007 at 8:16 AM
green 12-pin above fuse. thats the correct wire. used it multiple of tiems.
------------- Houston,TX
Date Posted: January 20, 2007 at 8:18 AM
so... it's the green wire in the 12-pin BLUE plug above the fusebox right? thx.
Date Posted: January 20, 2007 at 2:05 PM
that was the wire. thanks profuse.
Date Posted: January 20, 2007 at 3:27 PM
np. glad things work out for you.
