BMW door lock wiring mystery
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=89448
Printed Date: May 17, 2024 at 9:34 AM
Topic: BMW door lock wiring mystery
Posted By: kbert777
Subject: BMW door lock wiring mystery
Date Posted: January 23, 2007 at 9:15 PM
Can somebody please help me make some sense out of this Chinese wiring diagram that came with an Inwells Auto Security System 3205B. The primary wiring is no problem, what has me confused is the that there are no instructions for the power door locks, just 6 wires in the top of the diagram labeled 'Layout graph of central control lock' with the colors orange, white (with in-line fuse), yellow, ORANGE / black, WHITE/ black (no in-line fuse), yellow/black.
I am trying to install this alarm into an '88 BMW Si, here is a link to vehicle diagram:
https://www.the12volt.com/installbay/detail.asp?info=alarm&year=1988&make=BMW&model=325&ID=2270&type=Alarm
The manufactures website is no help, just responses in the same style, no details on internal wiring. This is the only documentation that came in the box.
Thank you very much in advance,
Klaus
Posted By: the12volt
Date Posted: January 23, 2007 at 9:29 PM
NO = Normally Open
NC = Normally Closed
C = Common
On an SPDT relay
87 = Normally Open
87a = Normally Closed
30 = Common
https://www.the12volt.com/doorlocks/doorlocks.asp
posted_image the12volt • Support the12volt.com
Posted By: kbert777
Date Posted: January 24, 2007 at 8:11 AM
the12volt wrote:
NO = Normally Open
C = Common
On an SPDT relay
87 = Normally Open
30 = Common
Ok, that makes perfect sense. Just a few other questions.
What could be the switch logic? I one relay activated with the lock button and the other one with the unlock button? Also, do I have to add external relays or is it safe to assume that the alarm module is constructed with internal relays that can handle the current of BMW's factory lock system?
Thanks,
Klaus
Posted By: KarTuneMan
Date Posted: January 24, 2007 at 10:54 PM
Your unit has "built in" door lock relays. I would love to help you more, BUT....you need to post the year and series of you Beemer.
posted_image
Posted By: bmwpwner
Date Posted: January 24, 2007 at 11:55 PM
i am assuming that you are working on an '88 325si. regardless, BMW have a central locking system and not really a "power door lock" system. this means that rather than having a switch on the console or on the driver's door to lock and unlock the doors everything works off the driver's door. this means that when you lock and/or unlock the driver's door all other doors lock/unlock including the gas flap and the trunk. i personally opt for doing this the easy way which is adding an aftermarket door actuator in the driver's door. this generally needs 1 actuator and a pair (2) relays. wire the relays as you would for adding power door locks and then run the wiring into the driver's door to activate the aftermarket actuator. this will simplify your situation and running wiring into the door one time isn't that bad and you are really replicating what the car is used to anyway. good luck and hope this helps.
"I cannot teach anybody anything, I can only make them think."
-Socrates-
Posted By: kbert777
Date Posted: January 26, 2007 at 8:52 AM
posted_image
I am trying to install this into an '88 BMW 325iS, sorry for messing that up in the original post. What has me puzzled is that some of the literature points to installing an extra actuator into the drivers door, like necessary in early Nissan vehicles, and some don't. I went out this morning and tried to unlock the drivers door with the trunk lock and the drivers door opens and closes correctly when the trunk lock is moved. So I guess I am safe to assume that the drivers door has a functional actuator.
I am really not sure if the alarms internal relays are big enough to handle the current of the original locking system, maybe somebody can speak from experience here. I am also not sure how those relays are usually addressed, does the unlock button address one relay and the lock button addresses the other? I would assume this to be the correct way but have not gotten around to power the alarm up and do some testing.
Thanks in advance,
Klaus
Posted By: jihadmatar
Date Posted: February 17, 2007 at 1:29 PM
hello,
i am looking for some info on 1999 a4 2.8 quattro wiring diagram to find the main wire that goes from the vacuum pump to the door switch. it should show 12 v when can unlocked and 0 when locked. i am installing a XS-900S remote start combo. and i have problem with the door lock part because its a vacuum type.
please get me in the right direction if you can.the location and color of that wire will be great.
email is: jihadmatar@yahoo.com
Posted By: cutter1122
Date Posted: February 18, 2007 at 7:07 PM
direct ground
LockRED / GrayDriver's kick panel or door boot
UnlockGray/WhiteDriver's kick panel or door boot
ArmArms With Lock
DisarmDisarms with Unlock
Posted By: howie ll
Date Posted: February 20, 2007 at 5:13 PM
Thanks I already replied to this post then saw your reply! Incidentally holding lock wire gives total close.
