viper 791xv, 94 integra, won't start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=89699
Printed Date: May 30, 2024 at 7:57 PM
Topic: viper 791xv, 94 integra, won't start
Posted By: justinsouza
Subject: viper 791xv, 94 integra, won't start
Date Posted: January 28, 2007 at 1:35 PM
my personal car has a viper 791xv w/remote start in it, lately when its cold i havent been able to start the car, ill have to wait till its warmer out and then pull on the fusebox and it starts, after that its usually good for the rest of the day. the car doesnt even crank, its like the starter wire isnt hooked up, so i hooked my starter wire back up outside of the starter kill. no dice, next morning same problem, i went to honda and they said the main relay may be bad, i changed it and thought for sure this would fix it, the relays contacts on the circut side were burnt, this was yesterday, went out to my car and its didnt start again. any advice?
Posted By: captainzab
Date Posted: January 28, 2007 at 7:49 PM
Your starter could be bad, try tapping it while someone is cranking.
------------- Note: You Always Dont Get What You Pay For.
Posted By: jayno20
Date Posted: January 28, 2007 at 11:30 PM
how's ur battery? it could be dying...
i had a problem when the car wouldn't crank long enough when cold, i just had to relearn the tach at a higher RPM and then i haven't had a problem since... u could try that too.
Posted By: jayno20
Date Posted: January 28, 2007 at 11:31 PM
Posted By: dre187
Date Posted: January 29, 2007 at 11:22 PM
when the car actually does start, do you find you have to crank it longer then you would normally need to?
Date Posted: February 03, 2007 at 10:17 AM
the car wont crank at all when i have this problem, i changed the main relay and hooked the starter kill up outside the starter kill relay.
