what remote starter to buy
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=89908
Printed Date: June 11, 2024 at 5:56 PM
Topic: what remote starter to buy
Posted By: daddy249
Subject: what remote starter to buy
Date Posted: February 01, 2007 at 8:01 PM
I have a 2002 Chevrolet Silverado and I would like some input on witch remote starter would be better. I have been looking at the Valet 561T and the Ultra Start 1155. Also any input on a Bypass kit would be appreciated. Thanks.
Posted By: dre187
Date Posted: February 01, 2007 at 9:27 PM
Check out www.bypasskits.com for a list of modules. they make modules for almost every vehicle with a factory immobilizer as well as modules that can also control door locks, oem alarm, heated/memory seats, rear deforster, parking lights etc. As for the remote starter, i don't install either of those on a regular basis, although i would suggest checking out Viper or Autostart. Those two companys are my favourite and if you don't have too much experience with remote starters, i would stick with Autostart. Its one of the most installer friendly remote starters i haver installed. It also offers a very good price with comprable quality.
Posted By: throwback2332
Date Posted: February 01, 2007 at 10:15 PM
I like scytek 5000rs system, you can even control to cars with one remote.
------------- If it's not custom, then it's not you.
Posted By: jmacf14
Date Posted: February 01, 2007 at 11:21 PM
I love the ultrastart units. I have installed on my 2003 suburban 1500 an ultrastart 4270 2way r/s alarm with a bypasskit gmdl-bp. The by pass works the doorlocks, the factory alarm and immobilizer. very easy to install, and I haven't had a single problem going on 3 years now. If you dont want a 2way then ultrastart 2270 is bulletproof. and if you only want r/s only (no alarm) then the 1270 is the best bet.
------------- jmacf14
Posted By: imseth85
Date Posted: February 02, 2007 at 12:17 AM
Valet and viper are the same company....Directed electronics. They make awesome units, and they're all really easy to program. They last a long time too.
------------- Seth Alvo NY
Mobile Electronics Installer
Posted By: brhaugen
Date Posted: February 02, 2007 at 7:11 AM
I have installed both - they are both quality units.
Posted By: Twelvoltz
Date Posted: February 02, 2007 at 7:46 AM
My preference would also be DEI. The 561T you mention would work fine, however it is an add-on RS, which means you would have to use the factory remotes to activate the RS by pressing lock 2 or 3 times(this is a programmable option in the menu)pressing the lock button on the door would also activate and deactivate the RS. The factory remotes do not have the same operating range as the DEI would. If you are looking to keep cost to a minimum I would recommend you pick up either the 561R or the Avital 4100 they are the same exact unit, but the Avital comes with 2 remotes the Valet only comes with one. If you don't mind spending a little more I strongly recommend the Valet 562T or Avital 4200. These units have dedicated lock and unlock buttons.
Posted By: green6767
Date Posted: February 02, 2007 at 9:09 AM
I would have to go with the AstroStart units. The 4204 is a great pageback unit and the 2205 is also another great pageback unit, but just a bit cheaper without the LCD screen. I would also get the GMDL-BP bypass kit.
------------- Shaun, we are the same height, that is neat!
12V Installation Technician for Honda, Dodge, Chrysler, Toyota and Jeep.
Posted By: xtremej
Date Posted: February 02, 2007 at 10:38 AM
Compustar Pro is my prefered unit. Ultra Starts are good units also just beware of buying them from ebay....
Posted By: tragik
Date Posted: February 02, 2007 at 12:38 PM
The best auto starts on the market are made by Autostart. The AS-2400 is the king of remote starters. Great range, easy install, super reliable etc.
------------- Northstart.....or start it your damn self.
Posted By: profuse007
Date Posted: February 02, 2007 at 1:10 PM
^not sure if that is the best. DEI remote starter w/ a bitwriter can do so much on the features.
Not to mention, the newer DEI new units are endless w/ the features they have. DEI have new lines of RS w/ 1mile range. also DEI satellite relay pack is what set them away from other makers, making install neat.
however the as2400 do have couple of features DEI havent acquired. Their warranty doesnt seem to explicitly say the unit has to be installed by authorized dealer. That might be a thumb up for DIY'ers
------------- Houston,TX
