2006 grand cherokee laredo, alarm/rs
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=90188
Printed Date: May 03, 2024 at 10:03 AM
Topic: 2006 grand cherokee laredo, alarm/rs
Posted By: iceman5210
Subject: 2006 grand cherokee laredo, alarm/rs
Date Posted: February 07, 2007 at 8:56 PM
I need the wiring diagram for this one , if anyone could help me out ill be really thankful. Im installing an alarm w remote start .
------------- The Cat
Posted By: cutter1122
Date Posted: February 07, 2007 at 10:35 PM
12volts | lt. blue/red (20A) | + | ignition harness | Starter | pink/orange | + | ignition harness | Second Starter | PURPLE / brown | - | ignition harness | Notes: The second starter wire is negative trigger thru a 150 ohm resistor. MUST use a relay. Refer to DirectFax document 1084 for wiring information. | Ignition | pink/lt. green | + | ignition harness | Second Ignition | N/A | | | Third Ignition | N/A | | | Accessory | same as second starter wire | - | ignition harness | Notes: The accessory wire is negative trigger thru a 560 ohm resistor. MUST use a relay. Refer to DirectFax document 1084 for wiring information. | Second Accessory | N/A | | | Keysense | N/A | | | Power Lock | PURPLE / dk. green | - | driver door module in door | Notes: Lock is negative trigger thru a 330 ohm resistor. Unlock is negative trigger thru a 100 ohm resistor. MUST use relays.
Can also use the trigger wires for the door lock relays found at the instrument cluster, conn. 2. Lock is lt. GREEN/ dk. green in pin 5. Driver door unlock is tan/lt. green in pin 6. Passenger door unlock is PURPLE / lt. green in pin 7. | Power Unlock | same as power lock wire | | | Lock Motor | lt. GREEN/ lt. blue | 5wi | plug above fuses, pin 36 | Unlock Motor | lt. GREEN/ dk. green | 5wi | plug above fuses, pin 35 | Parking Lights+ | do not use, relay rests at gnd | | | Parking Lights- | (CAN data bus) (use hazards) | | | Hazards | WHITE/ dk. blue to WHITE/ tan | - | SCM, 16 pin plug, pin 16 | Notes: The SCM (Steering Column Module) is in the steering column. | Turn Signal(L) | use hazards wire | | | Turn Signal(R) | use hazards wire | | | Reverse Light | WHITE/ lt. green | + | IPM , conn. 2, pin 2 | Notes: The IPM (Integrated Power Module) is on the driver fender, behind the battery. | Door Trigger | see notes | - | each kick or cluster, conn. 3 | Notes: The LF door is purple in pin 6. The RF door is PURPLE / white in pin 7. The LR door is PURPLE / gray in pin 4. The RR door is purple / YELLOW in pin 5. Use all four wires and diode isolate each wire from each other and the control module. Refer to DirectFax 1076 for wiring information. | Dome Supervision | yellow/orange | - | any light or cluster, conn 2, pin 12 | Trunk/Hatch Pin | pur/org and pur/brn (glass) | - | DKP or cluster, conn. 3, pins 3, 2 | Hood Pin | pink/lt. blue (export only) | - | pin sw. or FCM, 24 pin plug, pin 23 | Notes: The FCM (Front Control Module) is on the driver fender, behind the battery. | Trunk/Hatch Release | ORANGE / purple | - | DKP or cluster, conn. 3, pin 8 | Notes: Meter this wire while opening the rear glass from the switch on the rear hatch.
The hatch release motor wire is ORANGE / gray (5wi) at the plug above the fuses, pin 25. | Power Sliding Door | N/A | | | Factory Alarm Arm | factory remote only | | | Factory Alarm Disarm | factory remote only | | | Disarm No Unlock | with ignition and Sentry Key | | | Tachometer | NOT RED / tan or dk. grn/lt. grn | ac | any ignition coil or fuel injector | Wait to start | N/A | | | Brake Wire | WHITE/ tan | + | brake pedal switch | Parking Brake | dk. GREEN / WHITE | - | switch or cluster, conn. 1, pin 16 | Horn Trigger | dk. GREEN/ orange | + | horn or IPM, conn. 2, pin 35 | Notes: The IPM (Integrated Power Module) is on the driver fender, behind the battery. | Memory Seat 1 | lt. GREEN/ orange | - | driver door module in door | Notes: The memory seats are negative trigger thru resistors. The resistor values are not known at this time. Cut the wire and meter it while pressing the memory seat buttons. | Memory Seat 2 | same as memory seat 1 wire | - | | Memory Seat 3 | N/A | - | |
note: for doorlock; alarm; 2e starter; acc. wire; and transponder bypass use CHDL7-PK2 www.bypasskit.com |
Date Posted: February 08, 2007 at 7:55 AM
Than you so much I do preciated.
