how to make remote start indication
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=90455
Printed Date: June 01, 2024 at 1:12 PM
Topic: how to make remote start indication
Posted By: megatfauzi76
Subject: how to make remote start indication
Date Posted: February 14, 2007 at 2:12 AM
Hai, Im using 561T remote start with my normal alarm. Anyone know what should I do..When I remote start my car..there is some indication ( example :- Siren chirp or alarm honk ) when it start cranking my engine? So that I know, remote start confirm start cranking my engine...Coz Im using 1 way alarm..Also Indication from the signal light...sometimes not easy to see.. Any idea and Suggestion?
Posted By: KPierson
Date Posted: February 14, 2007 at 5:29 AM
On my old DEI Viper 550ESP I bought the add on pager for it. I then wired up the (-) starter output signal to the pager input. Every time I remote started the vehicle the pager would go off, giving me audible confirmation that it started. If you can't see the parking lights I would be surprised if you could hear a siren chirp. You may be able to use a time delayed relay on the remote start status output to honk the horn or something like that. ------------- Kevin Pierson
Date Posted: February 14, 2007 at 6:54 PM
Thanks for the reply..I If I connect remote start status output ( I think its a BLUE wire rite? ) How long my horn will honk? Any idea? Also anyone know how to reduce my wait to start timing? Coz it only start after 15 sec? Can i reduce it?
Posted By: akainstaller
Date Posted: February 27, 2007 at 10:36 PM
i beleave u can run ur flash output to a relay thn a wire from ur relay to ur horn so when u remote start ur car ur ligts flash and ur horn honks
Posted By: imseth85
Date Posted: February 27, 2007 at 11:41 PM
that's insane, the horn would honk so much. But it's a sort of good idea. I think on that valet unit there is a pulse after start wire somewhere on some weird harness (I may be confused with the audiovox). Use that wire to honk the horn and it will honk after your car starts.
------------- Seth Alvo NY
Mobile Electronics Installer
Posted By: captainzab
Date Posted: February 28, 2007 at 12:28 AM
On the 561T, use the factory alarm rearm wire (GREEN / WHITE) and hook it up your vehichle's horn
this will honk your horn once, after your engine has turned on.
Note: if your vehichle has neg trigger horn (which most car does), no relay need. Hook it up directly.
Posted By: Chris Luongo
Date Posted: February 28, 2007 at 4:58 PM
I've tried that before.... a 1-second horn honk is LOUD!
On my mother's car, I connected the pulse-before-start ("factory alarm disarm") output to the high-beam headlights.
When the car is about to start, the lights flash brightly. If you park in such a way that you can see the back of the car, but not the front....you could trigger the backup lights instead.
