direct fax 1077
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=91797
Printed Date: May 11, 2026 at 4:08 AM
Topic: direct fax 1077
Posted By: pitoaudiovisual
Subject: direct fax 1077
Date Posted: March 16, 2007 at 8:34 PM
Does anyone know what Direct Fax # 1077 is ... Thanks in advance..
Confidence is the key to any project!!
Posted By: BNLUIS
Date Posted: March 16, 2007 at 10:05 PM
Same as this wiring, it isolates the Ignition/ accessory wire from the switch to prevent over grind upon take in over with the keyy so the Wire doesnt fee back trough the switch.
https://64.85.6.129/extrainfo/diagrams/14301_ALTIMA_NISSAN%20ACCESSORY%20ISOLATION%20CIRCUIT.pdf
Luis
Sound Waves
Is up to the installer to test all wires with a DMM whenever possible.
Posted By: fkelsey
Date Posted: March 16, 2007 at 10:10 PM
posted_image
