viper 5002, 2007 chevy impala
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=91966
Printed Date: April 28, 2024 at 3:45 PM
Topic: viper 5002, 2007 chevy impala
Posted By: nava94
Subject: viper 5002, 2007 chevy impala
Date Posted: March 20, 2007 at 11:48 PM
hey guys is the 2007 chevy impala alarm wiring diagram the same as the 2006?
Posted By: profuse007
Date Posted: March 21, 2007 at 12:20 AM
2007 CHEVROLET IMPALA 4DR SEDAN WITH 3.5L ENGINE AND STANDARD AUDIO SYSTEM
Battery RED / WHITE (10 AMP) (+) IGNITION HARNESS ALSO IN THE BLUE BCM CONNECTOR PIN 3 Ignition 1 PINK (+) IGNITION HARNESS ALSO IN THE GREEN CONNECTOR AT THE BCM PIN 14 Starter 1 YELLOW (+) NOT USED FOR REMOTE START *SEE NOTE* ON V6 MODELS THE STARTER WIRE IS AT THE ECM BLUE PLUG PIN 26, AND ON THE V8(SS) MODEL THE STARTER WIRE IS IN THE BLACK ECM CONNECTOR PIN 22. All Door Trigger USE LATCH WIRES (-) DIODE ISOLATE YOU MUST DIODE ISOLATE BOTH TRIGGERS TO MONITOR ALL DOORS. Domelight Super GRAY/BLACK (+) DRIVERS KICK PANEL ALSO IN THE BCM PINK CONNECTOR PIN 1 LF Latch GRAY/BLACK (-) AT BCM PINK CONNECTOR PIN 10 RF Latch TAN/WHITE (-) AT BCM PINK CONNECTOR PIN 8 LR Latch BLUE/BLACK (-) BCM - PIN 15 RR Latch GREEN/ BLACK (-) BCM - PIN 14 Trunk Trigger ORANGE / BLACK (-) AT BCM PINK CONNECTOR PIN 12 Hood Trigger PINK/BLACK (-) AT BCM BLACK CONNECTOR PIN 17 Alarm Disarm SEE NOTES CAR MUST SEE A VALID KEY AND IGNITION 1 AT THE SAME TIME TO DISARM Alarm Arm RF ONLY Parking Lights LEFT VIOLET, RIGHT BROWN / WHITE (+) IN PASSENGERS KICK PANEL IN A HARNESS RUNNING TO THE REAR OF THE VEHICLE
------------- Houston,TX
Posted By: nava94
Date Posted: March 21, 2007 at 10:50 PM
have a 2007 chevy impala that im installing a viper 5002 2way alarm I want to disarm the factory alarm incase the factory alarm is armed the viper alarm will disarm the factory alarm but the only way is with the factory remote. can i put a duplicate key and wrap it around the key cylinder and give the ignition 1 voltage to disarm the factroy alarm this way or can I also use the 556u module? thanks in advance.trying to figure this thing out.
Date Posted: March 21, 2007 at 11:32 PM
I have not done a vehicle like this but the idea is to disarm(grn/wht on viper) via IGN 1 and bypass (556u or any other bypass) simultaneously.
relays and diodes are required.
www.bypasskit.com XK01 w/ right firmware will take care of both issues and bunch of other stuff.
Posted By: Mike M2
Date Posted: March 22, 2007 at 6:37 AM
I did an 05 a few weeks ago, same issue. DEI states it only disarms with the remote but that's not true. Try arming the factory alarm, then try disarming by turning the key to unlock in the drivers door. If it does(the one i did did) then you will find a wire in the drivers kickpanel coming from the boot that shows ground when you go to unlock with the key. This wire disarmed for me....
------------- Mike M2
Tech Manager
CS Dealer Services
