keyless entry problem 93 toy camry
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=92782
Printed Date: May 03, 2024 at 4:51 AM
Topic: keyless entry problem 93 toy camry
Posted By: jaycanode
Subject: keyless entry problem 93 toy camry
Date Posted: April 10, 2007 at 3:07 PM
Have installed a Directed Electronics Valet 712T into my Camry Wagon. The keyless entry works fine but seems to be overiding the factory doorlock switches. If I disable (unplug)the brain the switches begin working. I am tapped into the dark green and light green door lock wires in the drivers kickpanel. The brain does have internal lock relays. Have grounded the "common" wires from the brain. Where have I gone wrong?
------------- An eye for an eye makes the whole world blind--Ghandi
Posted By: captainzab
Date Posted: April 10, 2007 at 3:25 PM
use the wires below instead:
POWER LOCK BLUE/WHITE (TYPE B) IN PASSENGER KICK PANEL, BLUE PLUG
POWER UNLOCK LIGHT GREEN/ RED (TYPE B) IN PASSENGER KICK PANEL, BLUE PLUG
------------- Note: You Always Dont Get What You Pay For.
Date Posted: April 10, 2007 at 3:28 PM
Thanks, I'll give it a try.
