2003 pontiac vibe, alarm/remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=93297
Printed Date: May 23, 2024 at 9:50 AM
Topic: 2003 pontiac vibe, alarm/remote start
Posted By: Zeplin1073
Subject: 2003 pontiac vibe, alarm/remote start
Date Posted: April 24, 2007 at 5:58 PM
Hello all about to do a alarm/rs on a 03 vibe and was wondering if there is anything special I should know about. I had looked at the wire diagram and it said to use the keysense. has anyone else had to use the keysense and if so did it have any effects on the car later?
Posted By: KarTuneMan
Date Posted: April 24, 2007 at 7:14 PM
You need to send a ground while running signal to the key sence. This will prevent you from needing to disarm before remote starting.
Posted By: Chris Luongo
Date Posted: April 25, 2007 at 11:21 AM
That keysense stuff is BS.
There is no Vibe with a factory alarm, unless maybe a rare instance where it has the dealer-installed Toyota VIP security systme.
Don't need keysense.
Date Posted: April 25, 2007 at 12:09 PM
Yes it is BS....I read the info from the astrochart for a Toyota Matrix. Thinking , of course, since most of the information works on both cars.....I typed what I read. Miss information... SORRY BOUT THAT ONE KIDS.... Mr. Luongo has it correct....... -------------
Date Posted: April 25, 2007 at 11:03 PM
I think the people writing those tech sheets need to go out and get more coffee or something. They miss/ignore/neglect a lot of things.
The 2005-up Toyotas do have the transponder key, but still don't have the factory alarm.
Matrix, Corolla, or Vibe, none of them have a factory-installed alarm, at least not that I've ever run into.
Date Posted: April 26, 2007 at 1:49 PM
FACTORY ARM | Green | On BLUE 15-pin plug in driver's kick | - | | | This wire also locks the doors. When using this wire, no connection to the lock wire is needed. |
| FACTORY DISARM | Blue / YELLOW | On BLUE 15-pin plug in driver's kick | - | | | A single pulse disarms the alarm and unlocks the driver's door. A double pulse unlocks all doors. |
This is from wiremagic...... -------------
