2005 add on alarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=94621
Printed Date: May 04, 2024 at 10:47 PM
Topic: 2005 add on alarm
Posted By: dennis rider
Subject: 2005 add on alarm
Date Posted: June 08, 2007 at 9:18 AM
hello everyone, i am in need of a wiring chart for a 2005 dodge dakota ,i am trying to install a crimestopper keyless entry and alarm ...trying to find out which wires i need to tap into... thanks pvd41 ------------- pvd41
Posted By: rudydapimp
Date Posted: June 08, 2007 at 11:48 AM
12volts | red, RED / lt. blue, RED / orange | + | ignition harness | Starter | pink/lt. blue | + | ignition harness | Second Starter | N/A | | | Ignition | pink/lt. green | + | ignition harness | Second Ignition | pink | + | ignition harness | Third Ignition | N/A | | | Accessory | dk. blue and pink/white | + | ignition harness | Second Accessory | pink / YELLOW (x2) | + | ignition harness | Keysense | PURPLE / tan | - | ignition harness | Power Lock | PURPLE / dk. green | - | DKP or cluster, gry 16P plug, pin 3 | Notes: Lock is negative trigger thru a 330 ohm resistor. Unlock is negative trigger thru a 100 ohm resistor. MUST use relays. | Power Unlock | same as power lock wire | | | Lock Motor | lt. green | 5wi | DKP or cluster, gry 26P plug, pin 15 | Unlock Motor | tan/lt. green | 5wi | DKP or cluster, gry 26P plug, pin 12 | Parking Lights+ | pink/red (L), WHITE/ orange (R) | + | IPM, 20 pin plug, pins 15 and 17 | Notes: The IPM (Integrated Power Module) is the fuse/relay box on the driver side fender.
The rear taillight wires run from this location down into a harness that follows the frame rail to the rear of the vehicle. | Parking Lights- | pink/red | - | sw. or cluster, gry 16P plug, pin 5 | Notes: Parking lights are negative trigger thru a 1130 ohm resistor. MUST use a relay. | Hazards | WHITE/ orange | - | sw. or cluster, gry 16P plug, pin 8 | Notes: The hazard lights are negative trigger thru a 120 ohm resistor. MUST use a relay. | Turn Signal(L) | wht/lt. grn(F), wht/dk. grn(R) | + | FCM, 12 pin plg and IPM, 40 pin plg | Notes: The FCM (Front Control Module) is attached to the IPM (Integrated Power Module), which is the fuse/relay box on the driver side fender.
The rear taillight wires run from this location down into a harness that follows the frame rail to the rear of the vehicle. | Turn Signal(R) | WHITE/ tan (F), WHITE/ orange(R) | + | FCM, 12 pin plg and IPM, 40 pin plg | Notes: The FCM (Front Control Module) is attached to the IPM (Integrated Power Module), which is the fuse/relay box on the driver side fender.
The rear taillight wires run from this location down into a harness that follows the frame rail to the rear of the vehicle. | Reverse Light | WHITE/ lt. green | + | IPM, 40 pin plug, pin 27 | Notes: The IPM (Integrated Power Module) is the fuse/relay box on the driver side fender.
The rear taillight wires run from this location down into a harness that follows the frame rail to the rear of the vehicle. | Door Trigger | see notes | - | each kick or cluster | Notes: The LF door is purple in the gray 26 pin plug, pin 6. The RF door is PURPLE / white in the white plug, pin 23. The LR door is PURPLE / gray in the gray 26 pin plug, pin 8. The RR door is purple / YELLOW in the white plug, pin 22. Use all four wires and diode isolate each. | Dome Supervision | yellow/orange | + | cluster, white plug, pin 11 | Notes: Also found in the passenger A pillar. | Trunk/Hatch Pin | N/A | | | Hood Pin | N/A | | | Trunk/Hatch Release | N/A | | | Power Sliding Door | N/A | | | Factory Alarm Arm | arms on lock with door open | | | Factory Alarm Disarm | factory remote only | | | Disarm No Unlock | with ignition and Sentry Key | | | Tachometer | NOT red | ac | any ignition coil or fuel injector | Wait to start | N/A | | | Brake Wire | WHITE/ lt. blue | + | brake pedal switch | Parking Brake | dk. GREEN / WHITE | - | sw. or cluster, gry 26P plug, pin 3 | Horn Trigger | dk. GREEN/ purple | - | sw. or cluster, gry 26P plug, pin 10 | Memory Seat 1 | N/A | | | Memory Seat 2 | N/A | | | Memory Seat 3 | N/A | | | Interface Module: | Category: Combo Interface | Required: No | Type: Data Bus | Part #: IOM-Chrysler-7 | Notes: When using the IOM-Chrysler-7 it is not necessary to use doc 1084. That part takes care of 2nd starter and accessory, locks, and bypass. | Interface Module: | Category: Immobilizer Bypass | Required: Yes | Type: Sentry Key | Part #: 556CW | Alternate Part1 #: 556UW | Alternate Part2 #: DesignTech 20402 | Alternate Part3 #: DesignTech 29402 |
Posted By: KarTuneMan
12 VOLTS | RED / Orange & RED / blue | Ignition harness | + |
IGNITION | Pink/green | Ignition harness | + |
LOCK | Violet/green | SEE NOTES | - | | | Use a ground pulse through a 110-ohm resistor to unlock a ground pulse through a 300-ohm resistor to lock the doors. On fully equipped versions with memory seats, these wires will be located inside the driver's door. Without memory seats, this wire is found on a white plug near the fusebox. |
| UNLOCK | Violet/green | SEE NOTES | - | | | Use a ground pulse through a 110-ohm resistor to unlock a ground pulse through a 300-ohm resistor to lock the doors. On fully equipped versions with memory seats, these wires will be located inside the driver's door. Without memory seats, this wire is found on a white plug near the fusebox. |
DOORPIN | SEE NOTES | | | | | Doorpins are independent. Driver's door is Violet, passenger door is Violet/White, left rear door is Violet/Gray, right rear door is Violet / YELLOW. All wires are negative (-) and can be found iin their respective kickpanels or behind the instrument cluster. |
FACTORY ARM | Arms with lock wire | | | FACTORY DISARM | Through OEM remote only | | |
PARKLIGHTS | SEE NOTES | | | | | Use WHITE/ orange and Pink/red on the black connector at the fusebox (isolate with 2 relays). Or you can run a wire to pin #85 at the parking light relay under the hood. Turn on lightswitch and listen for clicking to find relay. |
Date Posted: June 10, 2007 at 8:58 PM
good evening, i have a dodge dakota 2005 slt...this has keyless entry only...no keysense or alarm...i want to install a crimestopper model 2002DC-IV...i am in need of the wiring for the power door lock/unlock and flashing parking lights at arm/disarm...also the door trigger wire... any help would be great many thanks ------------- pvd41
