window rollup module need relay?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=94994
Printed Date: May 11, 2024 at 4:58 PM
Topic: window rollup module need relay?
Posted By: mustang_pumpin
Subject: window rollup module need relay?
Date Posted: June 21, 2007 at 3:55 PM
I have installed a pyle security & remote start system in my carnot to long ago and i just purchased a window roll up module to install!! my question is... in my installation book for the alarm wire descriptions for the blue wire it says -- BLUE WIRE - dome light output (-) 500mA. the blue wire can be programmed for use as a 20 or 30 second timed output after either disarming the system (dome light) or after arming the system (window roll-up). - -Dome Light (default): connect to a relay to activate the vehicles dome light. - -Window Roll-up: connect to a relay or other device to operate windows modules or other desired features. i am not sure on if that is telling me a relay needs to be used even with the window rollup module i have or does that mean say if i didnt have the window rollup module then i would need to used a relay to works as the rollup module?? do i need a relay even with the rollup module i have??? and if i still need a relay even with the rollup module, can someone give me a diagram or explain how it would be hooked up correctly!!! thanks in advance for any help on this everyone!!!
Date Posted: June 21, 2007 at 4:00 PM
oh and the reason i ask is because in the blue wire description where it says Window Roll-up: connect to a relay or other device to operate windows modules or other desired features. its says connect to a relay or OTHER device to operate window modules..... is that other device meaning the window rollup module i purchased??
Posted By: phonymike
Date Posted: June 21, 2007 at 9:13 PM
what window module did you buy? I got the DEI 530T but have yet to install it. the 530T detects when the window is all the way up or down because the strain on the motor, and will then cut the power to the motor. if you were to connect a relay to your alarm and have it put the windows up every time you arm the alarm, then it will power the motor for 20-30 seconds, even if the window is all the way up, thus causing the motor to heat up and eventually leading it to fail. so yes you can hook that domelight lead up to your module, if it has a ground input that will trigger it to roll the windows up. but do not connect anything to your domelight lead (not even a light bulb) besides a relay or the ground input of your window module. if any device sucks more than 500ma from your domelight lead, then it will cause damage to the alarm. for instance my domelight is a 5watt bulb. 5watts divided by 12volts is about 417ma. my viper puts out only 200ma on the domelight, so I hooked a micro relay up to it, because the micro relay can handle 10amps.
Date Posted: June 21, 2007 at 10:11 PM
wth i just posted a reply and it isnt showing it!!! damn it i better not have to re type it all!!
Date Posted: June 21, 2007 at 10:17 PM
https://www.partsexpress.com/pe/pshowdetl.cfm?&Partnumber=330-125&Cfid=208220&CFTOKEN=13280884 that is the module i have!! unit has 8 wires--- PINK = to accessory item, GREEN = left motor, WHITE = left switch, ORANGE = 500mA.activation, BLACK = ground, RED = +12volts, BLUE = right motor, BROWN = right switch i know all about using just a relay to rollup windows and how it damages motors like you explained... which is why i never did that and purchased this window rollup module!! so a relay is not needed to hook up the rollup module i have at all??? i should be able to hook up each wire on the module to the corresponding wires in my car and thats all???
Date Posted: June 21, 2007 at 10:20 PM
also.. lets say if i wanted to use this window rollup module to roll down windows upon disarming would i be able to use it for that also do ya think or probably not??
Posted By: ceasar326
Date Posted: June 22, 2007 at 11:03 PM
I have an autopage model AC-78. This one has 15 wires, Becouse its a down and up roll up module. As far as i know on the relay's theres 3 types of window systems. A,B, and C. To find out wat type of system your car has use these steps from my autopage manual. Type A, The power window control swiches for a type A window system never changes polarity when the ingnition key is turned on. The swiches in a type A system either rest at ground or rest open (no connection). The swiches in a type A system will either switch +12 volts and ground at the same time to achieve up or down window motor polarity, or both wires will be resting at ground and when the window switch is activated, one wire will switch to +12 volts while the second wire will remain grounded (same as a 5 wire power door lock system). In all variations of the type A system, the power window control switches always provide +12 volts output to operate the window motors. Type B, The power window control swiches in a type B system change polarity when the ingnition key is turned on. The wires in a type B system will rest at ground untill the ignition key is turned on. Once the ignition key is turned on and the window switch is activated. the window switch will provide a ground signal to the window motor. (Just the reverse of a type A system). For the type B system, two additional relays must be added to reverse the polarity of the switchesd ground output wires. Typre C. The power window controlswitches in a type C system are the same as in a type A system with one exception. The window motors in a type C system are grounded by the moter housing ans use two different coil windings to run the window motor up and down. Type C window systems are rare nut it is important to make a simple test to insure that the vehicle you are working on does not use the type C window system. Testing windows Using a voltmeter, test and locate the Up+ and Down+ wires provided by the window control switches for both the drivers and passengers window.
Date Posted: June 23, 2007 at 9:35 AM
To test for a type B window system, turn on the ignition key and Up and Down wires will show ground when the control switch is activated. If the system you are working with test like a type A system, make another test to make sure it is not a type C system. After you have located the Up+ and Down+ wires for one of the windows, pull the wire plug off the window switch and test the same Up+ and Down+ wires to see if they are GROUNDED. If the Up+ and Down+ wires are GROUNDED when the plug is pulled from the switch, this is a type C system. Follow the wiring for the type Csystem. Hope this information works for you!
Date Posted: June 23, 2007 at 9:52 AM
well im pretty dang sure my car has type a system!! i have a 2001 ford mustang so if i might be wrong maybe u know different? but my whole question is if i relay is not needed since i have the window rollup module!! i read that the module i have has the auto stop sensing and all so i would think i dont need a relay to hook up the module!!!
Date Posted: July 02, 2007 at 4:17 AM
so where did all my helpers dissappear to now???? no one has posted a reply in a while so whats up?? replies with any tips or help asap would be appreciated very muchh!!! thanks
Posted By: xtremeaudio
Date Posted: July 04, 2007 at 5:33 AM
if you use the window module for roll up it have replay buit in you don't need relay hook the ORANGE to bule on alarm and on the window roll down you can use 2 relay to make it 86 and 87 go to 12v+ 85 go to alarm tirger when you press buton the window go down 87 go to window swtich side and 30 go to window motor side
Date Posted: July 05, 2007 at 6:46 PM
FINALLY the answer i was looking for!!!! THANKS alot man!! i figured it had a built in relay but just needed to be certain about it before i installed it!! THANKS AGAIN
Date Posted: July 07, 2007 at 1:16 PM
OK another question for someone..... The alarm i have installed has a blue wire activation which is programmable to be set for..... Disarm 20sec, Disarm 30sec, Arm 20sec, or Arm 30sec!!! yesterday i installed the rollup module that i have and am using that wire for activation and i have it programmed for Arm 20sec and everything works great... the windows roll up completely without a problem!!! :) my question is... couldnt i program that wire for Disarm 20sec and instead of connecting the module wires to the window up controls, connect them to the down switch and be able to use it to roll down the windows when disarming instead of using it for rollup upon arming???? I can do that if i wanted to and it should work without a problem also right????
