Remote Start, 07 Dodge Ram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=95175
Printed Date: April 30, 2024 at 3:13 PM
Topic: Remote Start, 07 Dodge Ram
Posted By: praux
Subject: Remote Start, 07 Dodge Ram
Date Posted: June 27, 2007 at 11:45 PM
I was just wondering if I'm going to need any relays or a bypass or anything for the door locks. I didn't see anything about it when I searched. The alarm is a Hornet 564T. I don't have keyless entry currently, it's just a regular black key. And just to make sure, all I need for the remote start is 2 relays?
Posted By: enice
Date Posted: June 28, 2007 at 7:01 AM
It is a PURPLE / drk.green wire at Driver Kick Panel or cluster small gray plug, pin 3. Lock is negative trigger thru an 820 ohm resistor. Unlock is negative trigger thru a 330 ohm resistor. MUST use relays.
Posted By: vitrox
Date Posted: June 28, 2007 at 3:20 PM
if you have a factory alarm you need to use a data module to integrate locks.
Posted By: praux
Date Posted: July 02, 2007 at 11:12 PM
I'm TRYING to get the remote start working on an 07 Dodge Ram. I have searched and I have a few questions but I have to start a new topic, anyways I got this from another post,
"any 07 that i have done so far doesn't have a starter wire, just the PURPLE / brown mux wire and pink/white ignition so the wiring procedure is different that an 06. Checking to see if your specific truck has the starter wire would be the first step. If it does, its just like the 06. What kind of remote starter are you installing? You will need 1 or 2 relays depending if your brand has an onboard relay. Here is how i do them with AstroStart and the onboard relay:
Relay 1
* 86: 12V * 87: ground through 560 ohm resistor * 87a: (-) pulse before through 8.5 kohm resistor * 85: (-) Accessory programmable output from RS * 30: goes to 87a on the onboard relay on the RS
Onboard Relay
* 30: to PURPLE / brown at ignition harness * 87a: to 30 at relay mentioned above * 87: ground through 180 ohm resistor * Onboard relay programmed for starter output
Hope this works out for ya. It has worked well for me so far. Im sure you can figure it out if you dont have the onboard relay, you would just have to wire up 2 relays. Post up with any questions."
I don't have a factory alarm or keyless entry. I didn't see an answer to this, 87a on the first relay, what does it hook up to? The PURPLE / brown wire? Also i'm using a Hornet 564T, it has the relay pack, is that what I'm going to be using as a second relay? If so, what wires are considered to be #30, 87,87a, etc. I'd love someone forever if I could get a diagram.
Posted By: INSTALLER_MSS
Date Posted: July 03, 2007 at 12:56 PM
12volts | lt. blue/red (2A) | + | ignition harness | Starter | yel/gry (not for remote start) | + | near battery, gray plug | Notes: There is no positive starter wire required for remote start. Just use the negative second starter wire. | Second Starter | PURPLE / brown | - | ignition harness | Notes: The second starter wire is negative trigger thru an 180 ohm resistor. MUST use a relay. Refer to DirectFax document 1084 for wiring information. | Ignition | pink/white | + | ignition harness | Second Ignition | N/A | | | Third Ignition | N/A | | | Accessory | same as second starter wire | | | Notes: The accessory wire is negative trigger thru a 610 ohm resistor. MUST use a relay. Refer to DirectFax document 1084 for wiring information. | Second Accessory | N/A | | | Keysense | N/A | | | Power Lock | PURPLE / dk. green | - | DKP or cluster, sml gry plug, pin 3 | Notes: Lock is negative trigger thru an 820 ohm resistor. Unlock is negative trigger thru a 330 ohm resistor. MUST use relays.
Can also use Directed interface module. | Power Unlock | same as power lock wire | | | Lock Motor | lt. green | 5wi | DKP or cluster, white plug, pin 10 | Unlock Motor | tan/lt. green | 5wi | DKP or cluster, white plug, pin 1 | Parking Lights+ | WHITE/ yel (L), WHITE/ gray (R) | + | harness at top of driver fender | Parking Lights- | WHITE/ lt. green | - | sw or cluster, sml gry plug, pin 5 | Notes: Parking lights are negative trigger thru a 1130 ohm resistor. MUST use a relay. | Hazards | WHITE/ orange | - | sw or cluster, sml gry plug, pin 8 | Notes: Hazards are negative trigger thru a 120 ohm resistor. MUST use a relay. | Turn Signal(L) | wht/lt grn (F), wht/dk grn (R) | + | harness at top of driver fender | Turn Signal(R) | WHITE/ tan (F), WHITE/ yel (R) | + | harness at top of driver fender | Reverse Light | WHITE/ lt. green | + | harness at top of driver fender | Door Trigger | see notes | - | each kick or cluster, lrg gray plug | Notes: The LF door is purple in pin 1. The RF door is PURPLE / white in pin 4. The LR door is PURPLE / orange or PURPLE / gray in pin 2. The RR door is purple / YELLOW or tan / YELLOW in pin 3. Use all four wires and diode isolate each wire from each other and the instrument cluster. See DirectFax document 1076 for wiring information. | Dome Supervision | yellow/lt. blue | + | A pillar or cluster, wht plg, pin 21 | Trunk/Hatch Pin | N/A | | | Hood Pin | PURPLE / lt. blue | - | hood pin switch | Trunk/Hatch Release | N/A | | | Power Sliding Door | N/A | | | Factory Alarm Arm | arms on lock with door open | | | Factory Alarm Disarm | factory remote only | | | Disarm No Unlock | with ignition and Sentry Key | | | Tachometer | dk. blue/gray | ac | PCM, BLACK/ orange plug, pin 34 | Notes: The PCM is on the passenger side firewall. The BLACK/ orange plug is the second plug down from the top.
On SRT-10 models, the tach wire is in the top black plug, pin 18.
On diesel models, the tach wire is at the ECM on the lower driver side of the engine, front 60 pin plug, pin 24, or at the camshaft position sensor just left of the ECM, in a 3 pin plug.
On gas models, can also go to any ignition coil or fuel injector and use the wire that is NOT BROWN / white. | Wait to start | see DirectFax document 1091 | | | Notes: On the remote start, make sure to program the Accessory State During Wait To Start to ON. | Brake Wire | WHITE/ tan | + | brake pedal switch | Parking Brake | dk. GREEN / WHITE | - | sw or cluster, lrg gry plug, pin 22 | Horn Trigger | dk. GREEN/ purple | - | sw or cluster, lrg gry plug, pin 14 | Memory Seat 1 | N/A | | | Memory Seat 2 | N/A | | | Memory Seat 3 | N/A | | | Interface Module: | Category: Combo Interface | Required: No | Type: Data Bus | Part #: IOM-Chrysler-7 | Notes: When using the IOM-Chrysler-7 the module will control the locks, trunk, door trigger, and bypass but it is still necessary to use doc 1084 for 2nd accessory and starter. Do not hook up the pink/white multiplex output from the IOM-Chrysler-7 to the PURPLE / brown in the vehicle. Use doc 1084 instead. | Interface Module: | Category: Immobilizer Bypass | Required: Yes | Type: Sentry Key | Part #: 556CW | Alternate Part1 #: 556UW | Alternate Part2 #: DesignTech 20402 | Alternate Part3 #: DesignTech 29402 | Notes: Standard on all models. | Interface Module: | Category: Door Lock Interface | Required: No | Type: Multiplex |
------------- "If a man made it, another can modify it...it just takes some thinking."
"If you ask questions, you're a fool for 5 minutes; if you don't, you're a fool for a lifetime."
Date Posted: July 03, 2007 at 1:00 PM
doorlocks are single wire through resistors and relays. there is a starter wire, it's a negative wire and it's also the accessory wire, also run trough relays and resistors. in short you are gonna need 5 relays and a handful of resistors to do this truck: two for locks, two for starter/acc. and one for lights, unless the unit has an option for negative light ouptput. i have done several of these and they are still not too difficult if you just pay close attention. if you need any help just ask. also, i have never had to use an integration module on a dodge truck for locks.
Date Posted: July 03, 2007 at 1:02 PM
if i'm not mistaken, transponders are on all models starting in 07...but i could be mistaken
Posted By: praux
Date Posted: July 03, 2007 at 6:34 PM
Thanks Installer_mss. I was mistaken, I do have a sentry key, thats it though. I've seen 3 different wiring diagrams on how to wire up the relays and resistors, and I've tried them all. I don't know how else to wire it. Can someone show me the correct one?
Posted By: praux
Date Posted: July 03, 2007 at 9:04 PM
ignore me, it helps if I put the toggle switch in the right position. :(
Date Posted: July 04, 2007 at 2:12 AM
lol...it happens man
