2001 jeep cherokee, door locks
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=95296
Printed Date: May 20, 2024 at 3:07 AM
Topic: 2001 jeep cherokee, door locks
Posted By: dinodon1
Subject: 2001 jeep cherokee, door locks
Date Posted: July 03, 2007 at 12:07 AM
I need help with connecting wires to door locks , Bought a commando ke-30i keyless entry with starter kill and it didnt have clear instructions on the wiring of the power door locks.I know where the signal wires are but use relays or not? The product came with one relay for the starter kill function only.If i use relays how do i wire them in? 2001 jeep cherokee without factory alarm.
Posted By: INSTALLER_MSS
Date Posted: July 03, 2007 at 1:14 PM
is it a cherokee or grand cherokee. they both have two different lock systems. ------------- "If a man made it, another can modify it...it just takes some thinking."
"If you ask questions, you're a fool for 5 minutes; if you don't, you're a fool for a lifetime."
neither are fun by the way
Posted By: dinodon1
Date Posted: July 03, 2007 at 3:23 PM
its not a grand just a regular cherokee
Posted By: xtremej
Date Posted: July 03, 2007 at 4:02 PM
Negative trigger locks ORANGE / purple lock------pink/purple unlock. location drivers kicks or at the module to the right of the steering column. Always verify with a dmm prior to conecting....
Posted By: dinodon1
Date Posted: July 03, 2007 at 5:52 PM
Use relays or No? commando ke-30i keyless entry w/starter kill. I know how to wire it without relays but need help with a diaghram to use relays to the unlock and lock trigger from the alarm
Posted By: KarTuneMan
Date Posted: July 03, 2007 at 8:44 PM
Well knowing how to wire the relays..... hmmmm. I looked at the install manual on line. This unit has negative lock triggers, AND posative triggers. Use the negative for how I suggested wiring your relays. pin 87 to ground pin 86 to 12volts pin 85 negative trigger from your unit pin 30 output to the lock/unlock wires. pin 87a not used -------------
Date Posted: July 04, 2007 at 2:15 AM
i must have somehow got the wrong diagram...my bad. cherokee is normal...grand cherokee is a pain
Posted By: harrisell1
Date Posted: July 13, 2007 at 10:24 PM
Speaking of locking systems, mine just started doing this. I have 99 jeep cherokee classic with the autopage 860 driver door priority and when I'm driving, the drivers door starts getting signals to unlock. It's not all the time. I haven't open up the door panel yet to see if something is touching but for now I want to go into the program and take off the ignition unlock. Is there a target area I need to look first to see what is causing this.
------------- electronics
