Someone Knows where can i get the wiring diagram for alarm installation for a Toyota Corolla 2003
ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|white & black |+ |ignition harness |
| STARTER|red |+ |ignition harness |
| SECOND STARTER| | | |
| IGNITION|BLACK / YELLOW |+ |ignition harness |
| SECOND IGNITION|BLACK/ white |+ |ignition harness |
| THIRD IGNITION| | | |
| ACCESSORY|blue/red |+ |ignition harness |
| SECOND ACCESSORY| | | |
| POWER LOCK|green *1 |- |passenger kick panel |
| POWER UNLOCK|blue/black *1 |- |passenger kick panel |
| LOCK MOTOR|blue | |driver kick, door harness |
| UNLOCK MOTOR|red | |driver kick, door harness |
| DISARM DEFEAT|red | |driver kick, harness to rear|
| PARKING LIGHTS +|green | |driver kick panel |
| PARKING LIGHTS -|GREEN / WHITE | |headlight switch |
| HEADLIGHTS|red |- |headlight switch |
| DOOR TRIGGER|RED / yellow |- |driver kick panel |
| DOME SUPERVISION|comes on with unlock| | |
| TRUNK/HATCH PIN|RED / white |- |light in trunk |
| HOOD PIN| | | |
|TRNK/HTCH RELEASE| | | |
| FCTRY ALARM ARM| | | |
|FCTRY ALRM DISARM| | | |
| DISARM NO UNLOCK| | | |
| TACHOMETER|*2 | |ignition coils |
| SPEED SENSE| | | |
| BRAKE WIRE|GREEN / WHITE |+ |brake pedal switch |
| HORN TRIGGER|GREEN / WHITE |- |steering column |
| WIPERS| | | |
| LF WINDOW UP/DN| | | |
| RF WINDOW UP/DN| | | |
| LR WINDOW UP/DN| | | |
| RR WINDOW UP/DN| | | |
| SUN RF OPN/CLOSE| | | |
| SUN ROOF LIMIT| | | |
| RADIO 12V| | | |
| RADIO GROUND| | | |
| RADIO SWITCH| | | |
| RADIO ILLUMINATE| | | |
| POWER ANTENNA| | | |
| LF SPEAKER| | | |
| RF SPEAKER| | | |
| LR SPEAKER| | | |
| RR SPEAKER| | | |
Notes:
*1 These are the passenger key cylinder wires. Meter the wires while turning the key in the passenger door. *2 Go to any one of the ignition coils under the black motor cover and use RED / blue, YELLOW /GREEN, gray, or white.
Have you already done a search? You should always do a search first; we had a 23-response long post about the Corolla recently.
Actually it was a 30 post , Chris
Toyota Corolla 2003
Click the above link for a detailed look at the installation by Chris.
