I have a 2007 Ford F350 that I just installed a Code Alarm CA680. When I hit the lock button on the remote it tells me that I have an open door and about every 10 seconds honks the horn. I notice that when I hit the lock button the dome lights do not go off which I am sure is part of the problem. If I let the dome light shut off before hitting the lock button it shows ARMED on remote but it still honks horn about every 15-20 seconds. Any help would be greatly appreciated. Brent
07 F350
Where did you pick up your door pins. Are they isolated (diodes) ? This truck has a domelight delay as well. See if there is a programing option on your alarm to disreguard the dome for arming.
Horn honking....is this the factory alarm doing this? or did you hook up the horn honk?
I picked up the door pins in the driverside kick panel. I am not sure about isolated diodes? The alarm is hooked up to the horn. I do not think the remote has a option to disregard dome light.
07 F350
It won't be the remote that has this dome delay option, it's a programming issue on the install.
Is your alarm hooked to "all" of the pins (wires) If it is you WILL need to isolate them with diodes. UNLESS you are using a posative trigger. To isolate this one wire posative trigger you will need a relay.
You say the hornis hooked to the alarm, is the siren also going off when the horn is?
Thanks for the help. It ended up that I had not turned off the internal shock sensor and that was causing the horn to go off (I am running off external shock sensor). The truck does have a delay on the dome light. Remote flashes DOOR Open until light goes off and then armes fully. Problem solved!!
07 F350
