horn with siren on viper 5000
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=95722
Printed Date: May 23, 2024 at 3:22 PM
Topic: horn with siren on viper 5000
Posted By: jdmegcoupe
Subject: horn with siren on viper 5000
Date Posted: July 18, 2007 at 4:07 PM
Hello all I have a 93 Civic Ex Coupe I am installing a Viper 5000 into it I would like to make the horn of the vehicle work with the siren also as I am in a high theft area and alot of alarms here sound the same. Can anyone help me with this? Thanks -------------
Date Posted: July 19, 2007 at 11:45 AM
Help please 19 views and no response?
Posted By: swamprat323
Date Posted: July 19, 2007 at 12:30 PM
is the horn hook up to the viper unit H2/7 light brown wire. i belive horn will only go off with full alarm. mya have to do a programing change too under menu 3
Posted By: phonymike
Date Posted: July 19, 2007 at 8:48 PM
the horn output from the alarm can only power a relay. remove the horn fuse, or unplug the horns and honk the horn on the steering wheel, you should hear a relay clicking on and off somewhere. if not then you need to put your own relay in. look in your steering column for the horn wire (it throws a ground when honking, do not use a test light, use a multimeter,) and tap into that. if you catch it further down the line it may be after the factory relay and won't work. in my 01 prelude, I actually tapped in down below where my left foot is, so that there isn't a single wire running anywhere near the steering column.
