Directstart reviews, Accord wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=9590
Printed Date: May 23, 2024 at 4:49 AM
Topic: Directstart reviews, Accord wiring
Posted By: alkali
Subject: Directstart reviews, Accord wiring
Date Posted: February 16, 2003 at 12:45 AM
Hi all
Two questions here.
1. Anybody has experience with Directstart cs124 (from www.12voltshop.com). I'm planning on this module and I have seen couple problem with the 423 they're selling, I think velocity motor can help me on this.. ;) )
I'm locate in Toronto, ON, anybody know a cheaper place I can pick this up then 12voltshop? they're selling CAD120 + 25 for the bypass module for 2002 Accord.
2. Now down to the wiring diagram from this site for the 2002 honda accord. it listed as following:
Starter- Cut after Fuse Panel, not at Ignition Switch. (what does this mean? If i'm installing a starter, do I HAVE to connect it after the fuse panel? or I can disregard this comment and do it normally at the ignition harness?)
Ignition 3 - Power this or ABS Light on Remote Starter. (?? is this just the second ignition wire? what exactly does the comment means?)
Tach - Distributor, anyone know where this wire is under the panel? just trying to avoid running another wire from the engine compartment).
Seems like this is a really hard job according to the following link. :) Maybe I should take a trip to a mitchell-on-demand terminal.
Original page: https://www.the12volt.com/installbay/detail.asp?info=alarm&year=2000&make=Honda&model=Accord&ID=17963&type=Alarm
Thanks for any input.. this is a great place.. :)
Evan
yalkali@yahoo.com
Posted By: pecas
Date Posted: March 12, 2003 at 9:02 PM
i have the wiring diagram of honda civic i dont know if as the same of honda accord . amende_padilla@hotmail.com
Posted By: 2vmodular
Date Posted: March 12, 2003 at 10:17 PM
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|white |+ |ignition harness |
| STARTER|BLACK/ white *1 |+ |ignition harness |
| IGNITION|BLACK / YELLOW |+ |ignition harness |
| SECOND IGNITION|yellow |+ |ignition harness |
| ACCESSORY|WHITE/ black |+ |ignition harness |
| POWER LOCK|BLACK/ blue *2 |- |passengers fuse box *3 |
| POWER UNLOCK|orange |- |passengers fuse box *3 |
| LOCK MOTOR|WHITE/ red | |drivers fuse box |
| UNLOCK MOTOR|*4 | |drivers fuse box |
| DISARM DEFEAT|lt. GREEN/ red | |*5 |
| PARKING LIGHTS +|RED / black | |drivers fuse box |
| PARKING LIGHTS -|RED / yellow *6 | |steering column |
| HEADLIGHTS|blue/red |- |steering column |
| DOOR TRIGGER|BLACK/ white |- |passenger fuse box *7 |
| DOME SUPERVISION|use door trigger | | |
| TRUNK/HATCH PIN|orange |- |drivers kick panel *8 |
| HOOD PIN|yellow/red or yellow|- |hood pin switch or *13 |
|TRNK/HTCH RELEASE|WHITE/ red |+ |drivers kick panel |
| FCTRY ALARM ARM|*9 | | |
|FCTRY ALRM DISARM|*9 | | |
| DISARM NO UNLOCK|blue |- |*10 |
| TACHOMETER|blue | |tach test connector *11 |
| SPEED SENSE|blue/white | |*12 |
| BRAKE WIRE|WHITE/ black |+ |brake pedal switch |
| HORN TRIGGER|lt. GREEN/ blue |- |steering column |
| WIPERS| | | |
| LF WINDOW UP/DN|RED / yel - RED / blu |A |drivers door switch |
| RF WINDOW UP/DN|blu/wht - blu/yel |A |RF window switch |
| LR WINDOW UP/DN|RED / yel - RED / blu |A |LR window switch |
| RR WINDOW UP/DN|RED / yel - RED / blu |A |RR window switch |
Notes:
NOTE: This vehicle has an immobilizer system that needs to be bypassed when
adding remote start. Use DEI part number 555H or 555U. *1 Must interrupt
the wire between the keyswitch and the fusebox, not between the fusebox and
the starter, to keep the check engine light from coming on. *2 Use
BLACK/ white for lock and GREEN/ red for unlock on LX models without factory
security. These wires are located in a two pin gray connector by the front
of the drivers side fuse box. *3 in a green 20 pin connector. *4 yellow on
the EX and lt. GREEN/ red on the LX *5 located in the same plug as the door
lock wires. Also found in a 14 pin green plug at the drivers fuse box on the
EX model. *6 Only available on the EX model. *7 In a green 4 pin
connector. *8 Above the hood release in a gray 18 pin connector. On the DX
& LX models, also found in a 2 pin connector behind the drivers fuse box. *9
Arms and disarms with the door locks on the EX models. The LX models arm
only with the factory transmitter. *10 On the EX the wire is located at
the drivers power window switch, on the LX the wire is at the
keyless/security unit which is attached to the drivers underdash panel. *11
The tach test connector is located behind the battery on the 4 cylinder, and
on a bracket attached to the drivers side strut tower on the 6 cylinder
motor. The tach test connector is a white 2 pin connector, and may be
covered by a black rubber boot. *12 Located at the first plug on the ECM, it
is a 32 pin gray plug. The ECM plugs can be accessed by pulling up the carpet
on the passenger side of the center console. There are 4 plugs total. *13
On the EX models it is in a green plug next to the passenger side fuse box.
On the LX models it is at the keyless/security unit, if equipped, which is
attached to the driver side underdash panel.
Posted By: jrilla
Date Posted: March 12, 2003 at 10:21 PM
I am curious what problems you have seen with the 423?
------------- J Rilla
Owner/Installer
