06 kia sedona, aps 997
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=96931
Printed Date: May 17, 2024 at 4:57 AM
Topic: 06 kia sedona, aps 997
Posted By: pitoaudiovisual
Subject: 06 kia sedona, aps 997
Date Posted: September 06, 2007 at 4:37 PM
i installed a prestige APS 997 in an 06 Kia Sedona 6 months ago and for some reason now everytime they lock the doors the drivers door makes a buzzing noise and everytime they unlock the passenger door makes a noise any idea what it can be.. everything works and they do unlock and lock they just make noise now..
------------- Confidence is the key to any project!!
Posted By: rtperformance
Date Posted: September 06, 2007 at 9:26 PM
dose this all so happein from the switch or just when you use the system?
Posted By: eurobink
Date Posted: September 07, 2007 at 12:05 AM
its simple.. 06 sedona is a 20 min install. drop the dash panel and all connections are in your face.. i don't see an installer error here.. more like KIA workmanship shining thru.. ive been doing work for 2 kia dealers for the past 6 years.. like the other reply, does it happen from door switch too? im sure it does.. it's a simple negative pulse.. you couldnt replicate the problem on the next sedona if you tried.
Posted By: catalin capota
Date Posted: September 08, 2007 at 3:30 AM
The door lock actuators are most likely faulty.
Date Posted: September 09, 2007 at 9:45 PM
It does do it with the switch i just wondered because its an almost new car..
Date Posted: September 09, 2007 at 10:17 PM
Unfortunately it seems like the actuator in that door is faulty, but the fortunate thing is that it's under warranty.
Date Posted: September 10, 2007 at 6:53 PM
the alarm doesn't cancel the warranty ------------- Confidence is the key to any project!!
Date Posted: September 16, 2007 at 12:03 AM
I really dont think it is the bran new actuators. my guess is the lock puls duration or the puls its self set the brain to a shorter duration and or try to relay isolate the door locks then look at the actuator. (If it works form the car but not form the remote it must be thew remote.)
