odessey remote starter
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=97159
Printed Date: May 14, 2024 at 3:26 AM
Topic: odessey remote starter
Posted By: vtech010
Subject: odessey remote starter
Date Posted: September 16, 2007 at 12:47 AM
hello, i bought a honda odessey 2003 ex-l. it has a remote starter that was installed by the previous owner. but i do not have the key fob for it. the midel # in the module is gsx-1000 that the only info on the module and rec daye 09/06. does anyone know what brand name it is or know what remote will work with it?
thank you
------------- What do i do now?
Posted By: Chris Luongo
Date Posted: September 16, 2007 at 11:15 AM
Look again, and can you find an FCC ID number?
If so, you can type that in at www.remotesunlimited.com
Posted By: vtech010
Date Posted: September 16, 2007 at 2:09 PM
ok i have th fcc # from the back of the module i will try it at remotes unlimited and i will post the results. i was doing a image search ofn remote starters and i found that ultra remote starters look exctaly the same, wiring colors and everything matches, the antenna is also the same with programming button on it. does anyone here think that i may have a ultra starter unit?
thank you
Posted By: vtech010
Date Posted: September 16, 2007 at 5:03 PM
No luck yet. the muber does not come up
Posted By: Scott35
Date Posted: September 16, 2007 at 6:54 PM
Try searching for it on Google.
------------- Tacomacrew
Posted By: vtech010
Date Posted: September 16, 2007 at 7:44 PM
i have been trying for 3 days now haha, and all of a suden today i come up, its gemini gsx-1000, but their website does not work. has anyone heard of this brand before and if so where can i get transmitter for it?
thanks
