Print Page | Close Window |
2007 hyundai tucson wiring infoPrinted From: the12volt.comForum Name: Car Security and Convenience Forum Discription: Car Alarms, Keyless Entries, Remote Starters, Immobilizer Bypasses, Sensors, Door Locks, Window Modules, Heated Mirrors, Heated Seats, etc. URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=98340 Printed Date: May 23, 2024 at 8:14 AM Topic: 2007 hyundai tucson wiring info Posted By: lsondubz Subject: 2007 hyundai tucson wiring info Date Posted: October 26, 2007 at 10:29 AM Got one of these coming in next week, anyone give me the full info/directechs sheet?
Replies: Posted By: Twelvoltz Date Posted: October 26, 2007 at 1:10 PM Audiovox lists:
#511971: 2007 HYUNDAI TUCSON 4DR SUV WITH 2.0L ENGINE AND STANDARD AUDIO SYSTEM Audio/Mobile Video WIRE COLOR POLARITY LOCATION Battery RED (+) RADIO HARNESS Accesory YELLOW (+) RADIO HARNESS Ground BLACK (-) RADIO HARNESS Illumination PINK (+) RADIO HARNESS Dimmer GRAY (-) RADIO HARNESS Power Antenna GRAY/ORANGE (+) RADIO HARNESS Amp Turn On GREEN/ ORANGE (+) RADIO HARNESS LF Speaker (+) WHITE LF Speaker (-) BROWN RF Speaker (+) RED RF Speaker (-) BLUE LR Speaker (+) YELLOW LR Speaker (-) BLACK RR Speaker (+) ORANGE RR Speaker (-) BLUE Amp Location IN DRIVER SIDE CARGO AREA UNDER FLOOR Steering Cntrls NO Speed Cntrl NO Radio Security YES Security WIRE COLOR POLARITY LOCATION Battery RED (+) IGNITION SWITCH HARNESS Ignition 1 ORANGE (+) IGNITION SWITCH HARNESS Starter 1 PINK (+) IGNITION SWITCH HARNESS All Door Trigger YELLOW (-) AT VEHICLE FUSEBOX BEHIND DRIVERS SIDE OF DASH WHITE PLUG Domelight Super YELLOW (-) AT VEHICLE FUSEBOX BEHIND DRIVERS SIDE OF DASH WHITE PLUG Trunk Trigger GREEN/ BLACK (-) IN HARNESS IN DRIVERS KICKPANEL Alarm Disarm BROWN (-) IN HARNESS IN DRIVERS KICKPANEL Alarm Arm YELLOW (-) IN HARNESS IN DRIVERS KICKPANEL Parking Lights BLUE/BLACK (-) IGNITION SWITCH HARNESS Convenience WIRE COLOR POLARITY LOCATION Please select another category Remote Start WIRE COLOR POLARITY LOCATION Battery RED (+) IGNITION SWITCH HARNESS Ignition 1 ORANGE (+) IGNITION SWITCH HARNESS Accessory 1 PINK (+) IGNITION SWITCH HARNESS Accessory 2 YELLOW (+) IGNITION SWITCH HARNESS Starter 1 PINK (+) IGNITION SWITCH HARNESS Speed Sense GRAY/ORANGE (AC) IN PLUG UNDER DRIVERS SIDE DASH Parking Lights BLUE/BLACK (-) IGNITION SWITCH HARNESS Brake Lights WHITE (+) AT SWITCH ABOVE PEDAL Reverse Lights BROWN (+) IN HARNESS IN DRIVERS KICKPANEL Modules WIRE LOCATION Please select another category Doorlocks/Windows WIRE COLOR POLARITY LOCATION Power Unlock YELLOW (-) AT DOORLOCK CONTROL MODULE TO RIGHT SIDE OF STEERING COLUMN PowerLock YELLOW/ORANGE (-) AT DOORLOCK CONTROL MODULE TO RIGHT SIDE OF STEERING COLUMN LF Window Up BROWN (REV) AT MASTER WINDOW SWITCH HARNESS IN DRIVERS DOOR LF Window Dn ORANGE (REV) AT MASTER WINDOW SWITCH HARNESS IN DRIVERS DOOR RF Window Up GRAY (REV) AT MASTER WINDOW SWITCH HARNESS IN DRIVERS DOOR RF Window Dn GREEN (REV) AT MASTER WINDOW SWITCH HARNESS IN DRIVERS DOOR LR Window Up BLUE (REV) AT MASTER WINDOW SWITCH HARNESS IN DRIVERS DOOR LR Window Dn PINK (REV) AT MASTER WINDOW SWITCH HARNESS IN DRIVERS DOOR RR Window Up BROWN (REV) AT MASTER WINDOW SWITCH HARNESS IN DRIVERS DOOR RR Window Dn WHITE (REV) AT MASTER WINDOW SWITCH HARNESS IN DRIVERS DOOR Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation. I doubt if anyone will post the Directechs info anymore. DEI is monitoring directechs usage for "abuse" and posting their info is an abuse in their opinion. ------------- Installer, IT support, and FFL. I need less hobbies. |
