1996 riviera sc, remote start, vats bypass
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=98411
Printed Date: May 23, 2024 at 4:51 AM
Topic: 1996 riviera sc, remote start, vats bypass
Posted By: krypto
Subject: 1996 riviera sc, remote start, vats bypass
Date Posted: October 28, 2007 at 10:58 PM
1996 Buick Riviera SC
I just installed a Python 1400XP Remote starter,and purchased a Self learning Passlock Bypass,for Passlock 1 Passlock 2 and VATS. By Peripheral Electronics model # PPLJX They have since replaced this with model# PPLXR.
The remote starter works wit the key in the ignition,only in the ON position,however i can not get the bypass module to respond. It has power and the LED lights up. The VATS signal wires, White and white. but only 1 of the wires will allow me to connect to, the other disables the whole system altogether.
Wiring instructions Link:   https://peripheralelectronics.com/periph_products/Instructions/PPLXR.pdf
The only wires i connected were:
Brown: after programming.
Green: Key sense
Blue: VATS signal wire
Pink: Ignition
Red: 12v constant
because it says for VATS,and separates the others as Passlock 1 or 2 only.
Thanks for any help!
Posted By: dea,can
Date Posted: October 29, 2007 at 2:07 AM
posted_imagedid u program it to vats its default setting is passlock 2  for ions need to go to step 1 to chane it to vats
then program your resistor code after you  have changed it .
dragon
Posted By: krypto
Date Posted: October 29, 2007 at 7:35 AM
since i have the older model PPLJX  it has a jumper setting to select between VATS and passlock.
Posted By: dea,can
Date Posted: October 29, 2007 at 9:43 AM
for some reason i have done a few there is connector that plugs the vats together you will see  it  tap your wires on the computer side of that connector not the  keyside.
dragon
Posted By: krypto
Date Posted: October 29, 2007 at 1:35 PM
I think i know what your talking about, the 2 white wires go into a big distribution block/plug an go from double white ,to WHITE/ black and PURPLE / black.  as far as the other conections go did i hook up everything necessary?
Posted By: krypto
Date Posted: November 03, 2007 at 4:41 PM
I could not get the bypass module to work...so i just used basic resistors..but come to find out i didnt have enough power to power up the vats module,and computer..so i had to use the other 12v constant they supplied as a back up if needed,now everything works.
