Ignition Wiring for 1991 Toyota Levin
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=99025
Printed Date: June 01, 2024 at 1:04 PM
Topic: Ignition Wiring for 1991 Toyota Levin
Posted By: berryisaac
Subject: Ignition Wiring for 1991 Toyota Levin
Date Posted: November 15, 2007 at 3:17 AM
Hi does anyone have the ignition wiring diagram for a Levin/Treuno 1991. I want to install an alarm and keep blowing the AM1 40a fuse trying to find the Ignition wire and starter wire. I have a Fusion f-2000 alarm and i am trying to install a relay...? I tryed using the corolla diagram but unsuccefull
Posted By: Twelvoltz
Date Posted: November 15, 2007 at 7:46 AM
Just out of curiosity how are you 'blowing the AM1 40a fuse' while 'trying' to find the ignition and starter wires? To blow the fuse it sounds as if you have already made the connections to the wiring. To find the correct wires you should be using a DMM, each wire at the ignition harness will behave in a specific manner depending on the key position. Your constant hots will be +12V regardless of switch position, your accessory +12V wires will be hot in the run and accessory positions of the switch and drop out when going to the start position, your ignition wires will be hot in every position other than off and the starter wire will only be hot when the key is in the start position. I can not find any information on that specific vehicle but being a '91 it should be a fairly straight forward vehicle.
It is possible that the ignition switch causes the ignition or accessory wires to rest at ground in the off position which would require you to isolate the wires from the switch when remote starting. This would cause your fuse to blow when activating the remote start. To test for this, after all of your connections have been made and programming options (like tach programming) have been completed, disconnect the factory harness from the ignition switch and try to remote start the vehicle. If it remote starts and operates fine then you would need to isolate the switch during remote start, similar to what is required in the 93-97 Altima's. You would need to cut the wire that is resting at ground through the switch. I am not familiar with that particular brand remote starter but if it offers negative outputs for the accessory and ignition outputs it is a fairly simple process with relay(s) wired like:
86 and 87: Constant fused +12V
85 Negative out from remote start (either accessory or ignition depending on the requirement)
87a key side of cut ignition/accessory wire
30 vehicle side of cut ignition/accessory wire
Hope this clears things up a bit, or at least gives you a place to start looking.
------------- Installer, IT support, and FFL. I need less hobbies.
Date Posted: November 15, 2007 at 2:29 PM
cheers for that that helps me a bit but on my wiring diagram for my alarm it says
85-Engine Disable output which is rite.
30-starter solenoid?? Is this on the starter motor negative?
86-Ignition on
87 has nothing
87a start
And what do you mean by key side cut and vehicle side cut thanks??
Date Posted: November 17, 2007 at 7:21 AM
86-Ignition on
87 has nothing
87a start
This is a starter kill circuit. To install this circuit you need to cut the starter wire coming from the ignition switch, put the side of the cut wire that is coming from the key switch to 30 and the vehicle side of the cut wire to 87a.
I apologize but I did not realize this is just a security system not a remote starter too.
How did you interface with your door lock circuits? ------------- Installer, IT support, and FFL. I need less hobbies.
Date Posted: November 17, 2007 at 2:19 PM
yeah thanks now I should have it sorted
well i found a corolla wiring diagram and that had the colours of the unlock and lock i found them and cut them put the positive lock and unlock to each and put the negatives to the chassis
Date Posted: November 17, 2007 at 2:22 PM
oh and also how do I test the wires without cutting them because you have to have the key on to test them, I found the 12v constant easy, found the starter by one of the wires i had already cut but dont want to cut anymore to find the ignition wire?
Posted By: kola7126
Date Posted: November 19, 2007 at 2:12 AM
MODEL | YEAR(S) | COROLLA | 1988 -1992 |
KEY | T-HARNESS | IMMOBILIZER | N/A | N/A | N/A |
PART | COLOR | LOCATION | 12 VOLT CONSTANT | WHITE (+) or BLACK RED (+) | IGNITION SWITCH HARNESS | STARTER | BLACK/ WHITE (+) | IGNITION SWITCH HARNESS | STARTER 2 | N/A | | IGNITION 1 | BLACK / YELLOW (+) | IGNITION SWITCH HARNESS | IGNITION 2 | BLACK/ ORANGE (+) | IGNITION SWITCH HARNESS | IGNITION 3 | N/A | | ACCESSORY /HEATER BLOWER 1 | BLUE/RED (+) | IGNITION SWITCH HARNESS | ACCESSORY /HEATER BLOWER 2 | N/A | | KEYSENSE | N/A | | PARKING LIGHTS ( - ) | LIGHT GREEN (-) or LIGHT GREEN/ BLACK (-) | @ STEERING COLUMN HARNESS | PARKING LIGHTS ( + ) | DARK GREEN (+) | IN DRIVERS KICK PANEL | POWER LOCK | BLUE/WHITE (TYPE B) | IN DRIVERS KICK PANEL | POWER UNLOCK | BLUE / YELLOW (TYPE B) | IN DRIVERS KICK PANEL | DOOR TRIGGER | BLACK/ WHITE (-) or BLACK (-) | @ 2-PIN PLUG in FUSEBOX | DOMELIGHT SUPERVISION | USE DOOR TRIGGER, Requires Part #775 Relay | | TRUNK RELEASE | N/A | | SLIDING POWER DOOR | N/A | | HORN | GREEN/ RED (-) | @ STEERING COLUMN HARNESS | TACH | BLACK (-) | @ IGNITOR of FUSEBOX | WAIT TO START LIGHT | N/A | | BRAKE | GREEN / WHITE (+) | @ SWITCH ABOVE BRAKE PEDAL | FACTORY ALARM DISARM | WHITE/ GREEN (+) or BLUE/WHITE (+) | IN DRIVER KICK PANEL or THEFT MODULE | ANTI-THEFT | N/A | |
