2007 vw eos, remote start, keyless
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=99338
Printed Date: May 02, 2024 at 5:44 AM
Topic: 2007 vw eos, remote start, keyless
Posted By: mxxmikexx
Subject: 2007 vw eos, remote start, keyless
Date Posted: November 25, 2007 at 12:33 PM
does anyone having wiring info for a 2007 vw EOS? for remote start keyless
------------- Mike Battaglia
Specialized Car Audio
Bensenville IL 60106
Posted By: howie ll
Date Posted: November 25, 2007 at 12:36 PM
Use DEI CAN1 or similar and save a lot of heartache!
Date Posted: November 25, 2007 at 1:35 PM
i forgot to say that i am only doing a 1 button start, so i am not hooking up keyless, etc.
if anyone has the wiring info for this vehicle please post!
audiovox does not have it and i no longer have access to DEI's website.
Date Posted: November 29, 2007 at 9:06 PM
update: i used the fortin sl2i can interface which you can buy from tweeter for $50 if you dont have any other way of getting one, this is the best interface ive seen in awhile, covers about 180 different cars with a self learning mode, no need to flash different firmware. and much cheaper than the dei can interface which retails for $299!
install was very easy with this interface kit, hook up the hi and low can wires in the drivers kick coming in from the door harness
brake wire in a plug just left of the steering column
+12 and a heavy gauge wire left of steering column
start, acc, and ignition at steering column
parking lights behind switch you need to isolate one wire with a relay and tie the computer side to another wire.
universal keybox.
if anyone needs the wiring colors i will post them or PM them to you. i just dont have the sheet in front of me right now.
