2008 hyundai entourage
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=99383
Printed Date: April 27, 2024 at 7:00 PM
Topic: 2008 hyundai entourage
Posted By: slicksam
Subject: 2008 hyundai entourage
Date Posted: November 26, 2007 at 8:06 PM
I have a customer of mine that just bought the 08 Entourage. Anyone have information on this van? or anyone do one? any pics would be great? level of installing? 1 to 10 ( 1 being easy - 10 being really hard) ------------- Testing is the key
Posted By: kola7126
Date Posted: November 27, 2007 at 12:09 AM
MODEL | YEAR(S) | ENTOURAGE | 2007 - |
KEY | T-HARNESS | IMMOBILIZER | N/A | N/A | HYUNDAI'S TRANSPONDER ANTI-THEFT SYSTEM, Requires 791 Bypass Module and extra Programmed Ignition Key |
PART | COLOR | LOCATION | 12 VOLT CONSTANT | WHITE (+) | @ IGNITION SWITCH HARNESS | STARTER | ORANGE (+) | @ IGNITION SWITCH HARNESS | STARTER 2 | N/A | | IGNITION 1 | GREEN (+) | @ IGNITION SWITCH HARNESS | IGNITION 2 | N/A | | IGNITION 3 | N/A | | ACCESSORY /HEATER BLOWER 1 | BLUE (+) | @ IGNITION SWITCH HARNESS | ACCESSORY /HEATER BLOWER 2 | PINK (+) | @ IGNITION SWITCH HARNESS | KEYSENSE | N/A | | PARKING LIGHTS ( - ) | BLUE (-) | @ HEADLIGHT Switch or IMP, BLUE 72-Pin Plug, Pin 69. See NOTE *1 | PARKING LIGHTS ( + ) | DO NOT USE! | | POWER LOCK | MUST use FACTORY ALARM ARM wire, See NOTE *2 | | POWER UNLOCK | See NOTE *2 | | DOOR TRIGGER | See NOTE *4 | @ RAM, See NOTE *5, See DIAGRAM | DOMELIGHT SUPERVISION | BLUE (-) | @ RAM, RIGHT 16-Pin Plug, Pin 6, See NOTE *5 | TRUNK RELEASE | YELLOW/BLACK (-) | @ SWITCH | SLIDING POWER DOOR | WHITE (-) Left side and BLUE/BLACK (-) Right side | @ SWITCH or IMP, 42-Pin Plug, Pins 8 and 25, See NOTE *1 | HORN | YELLOW (-) | @ HORN Switch | TACH | PINK | @ IMP, BLUE 72-Pin Plug, Pin 64, See NOTE *1 | WAIT TO START LIGHT | N/A | | BRAKE | WHITE (+) | @ SWITCH ABOVE BRAKE PEDAL | FACTORY ALARM DISARM | RED (-) See NOTE *6 | @ Drivers Door Power window switch Connector 2 Pin 1 | ANTI-THEFT | HYUNDAI'S TRANPONDER ANTI-THEFT SYSTEM on Canadain Models Only!! | @ IGNITION SWITCH TUMBLER |
EXTRA INFORMATION | NOTE *1 The IPM Module is attached to the FUSEBOX under the Drivers Side of the Dash. NOTE *2 MUST use the FACTORY ALARM ARM (ORANGE) (-) or TYPE B, wire, Connector 2 Pin3,located in the DRIVERS DOOR at the Power Window Switch, to LOCK, to UNLOCK use the UNLOCK MOTOR wire PINK (TYPE C) Connector 1 Pin 4, located in the DRIVERS DOOR at the Power Window Switch. NOTE *3 located in the DRIVERS DOOR at the Power Window Switch. NOTE *4 The DRIVERS DOOR TRIGGER is a YELLOW (-) at the LEFT 42-Pin Plug, Pin 5, the PASSENGER DOOR TRIGER is a BLUE (-) at the RIGHT 42-Pin Plug, Pin 3. The DRIVERS REAR DOOR TRIGGER is a PINK (-) at the RIGHT 42-Pin Plug, Pin 4 and the PASSENGER REAR DOOR TRIGGER is a ORANGE (-) at the LEFT, 42-Pin Plug, Pin 8, when connecting to an ALARM SYSTEM use all (4) FOUR wires and DIODE ISOLATE, See DIAGRAM. NOTE *5 The RAM Module is attached to the FUSEBOX in the DRIVERS SIDE Cargo Area. |
Posted By: KarTuneMan
Date Posted: November 27, 2007 at 2:15 AM
2008........ is it the same as 07? This is what S. S. is after!
Posted By: slicksam
Date Posted: November 27, 2007 at 6:56 AM
Well thanks for the info. Looks like the hardest part is running 2 wires in the driver door. ------------- Testing is the key
Posted By: chadwa2003
Date Posted: November 27, 2007 at 8:01 PM
You can pull out the cluster and access all the wires behind it and get the 12 volt and brake in the kick panel. Get an xk01 and from bypasskit.com and it will do your door locks and sliding doors and power trunk if applicable.
