2001 jetta 1.8t remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=99634
Printed Date: May 09, 2024 at 3:13 PM
Topic: 2001 jetta 1.8t remote start
Posted By: shadowinfector
Subject: 2001 jetta 1.8t remote start
Date Posted: December 03, 2007 at 9:45 PM
I finished installing my Remote Start for my 2001 Jetta 1.8t, but when I remote Start the vehicle it makes a weird noise like the fuel pump is not turned on or something....any help please???
Date Posted: December 04, 2007 at 12:04 PM
anyone???? please has anyone done a 1.8t
Posted By: tedmond
Date Posted: December 04, 2007 at 2:24 PM
did u allow a delay on your remote start or hook up the wait-to-start wire on your car if it sa diesel, it allows the plugs to heat ur properly.
Posted By: enice
Date Posted: December 04, 2007 at 3:46 PM
Sounds like you have a transponder on that car. Your trying to say that the car doesnt turn on...you just hear the car trying to turn on? Try this out: Leave the key in the ignition(do not turn key at all) and see if it turns on when you remote start the car. Also, make sure your tach is learned.
Date Posted: December 05, 2007 at 9:47 AM
no....the Vehicle starts and everything but it makes a noise like somethings is not turned on like the fuel pump or something......everything has been doouble checked ...all wires metered....tach wire hoooked up and learned...tried three different tach signals.....but its definately something that is not turned on...and my car is not diesel....
Posted By: tedmond
Date Posted: December 05, 2007 at 3:58 PM
may i ask what unit you are using? lke company and model
Date Posted: December 05, 2007 at 4:05 PM
scytek 5000rs
Posted By: sarcomax
Date Posted: December 05, 2007 at 4:14 PM
Can you discribe the noise? is it a grinding, a clicking, a buzzing? Does it happen once and stop? Is it repetitive? Is it a constant noise for as long as the car is under control of the remote start? You could have missed an accessory wire. Is there any way that you could post up the wire colors that you made connections to?
Posted By: howie ll
Date Posted: December 06, 2007 at 2:25 AM
Ign switch VW group = red input (possibly 2) black or black /blue ign 1. BLACK / YELLOW or BLACK/ red ign 2 RED / black starter, thin red or yellow/red acc. These are suffient on a Mk IV /Golf.
Date Posted: December 07, 2007 at 7:25 PM
like a grinding noise and its constant and only happens when i remote start...as far as the wires.. i hooked up ...
red-12volt
starter-RED / gray
ign- black
acc-BLACK/ red
Posted By: howie ll
Date Posted: December 08, 2007 at 3:12 AM
This does sound like the starter motor grinding, are you sure the tach has been learned OR check your setting on the starter crank time.
Posted By: tedmond
Date Posted: December 08, 2007 at 7:49 AM
yeap thats engine grind for sure. Make sure u go the TACH method. it prevents overcrank and damage to ur starter.
Date Posted: December 08, 2007 at 5:16 PM
no, its definitely not engine grind....i know what that sounds like....
Date Posted: December 08, 2007 at 5:19 PM
the alarm i have does not have a engine crank time option and the tach is learned
Posted By: vitrox
Date Posted: December 08, 2007 at 5:31 PM
switch that unit over to "smart start" and see if it still does it. if it goes away its your starter grinding and you don't have a good tach. if your fuel pump wasn't turning on the vehicle would not run.
Date Posted: December 08, 2007 at 5:32 PM
Posted By: vitrox
Date Posted: December 08, 2007 at 5:38 PM
i would still try it, you have yet to specify where the noise is originating from so its pretty hard to diagnose over a forum.
Posted By: tedmond
Date Posted: December 08, 2007 at 8:07 PM
take a video of he car starting. that way we can hear and determine whats goinon.
Posted By: howie ll
Date Posted: December 09, 2007 at 1:58 AM
Easy way to find out, take 1 DMM, black probe to ground, red probe to starter output on R/S, set to 20vDC and use your remote, see for how long it gives a reading and if it concides with the noise! Better still use a test light, it's easier to tell.
Date Posted: December 09, 2007 at 2:34 PM
tested...and its not over crank
Date Posted: December 12, 2007 at 9:49 AM
i rechecked and tested all connections again...maybe im missing something, but has anyone done a jetta 1.8t before that can maybe help me out please. thanx
Posted By: KarTuneMan
Date Posted: December 12, 2007 at 8:05 PM
auto trans, manual? if manual how did you get around the clutch?
Date Posted: January 07, 2008 at 6:27 PM
manual trans, and i bypassed the clutch using a relay...any ideas?
Posted By: tedmond
Date Posted: January 07, 2008 at 6:59 PM
u used a relay to bypass the clutch but what method. N/C or N/O
Date Posted: February 13, 2008 at 9:00 AM
N/O
Posted By: Velocity Motors
Date Posted: February 13, 2008 at 12:47 PM
Remove the clutch bypass and sit in the vehicle and press the clutch down with your foot. If noise goes away, chances are it's your bypass for the clutch. I know it sounds weird but you need to start removing parts of the starting sequence in order to find out what part is actually the problem. Post your results.
BTW, I have done many manual trans VW's without a problem.
------------- Jeff
Date Posted: March 10, 2008 at 3:36 PM
thanx for the reply.....i am pretty sure i've tried that....but i haven't touched the car since.. the past couple of months...kinda waiting for the spring time...but i will check it out again... thanx
