2007/2008 tundra immobilizer
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=99671
Printed Date: May 15, 2024 at 5:48 PM
Topic: 2007/2008 tundra immobilizer
Posted By: tonyberg
Subject: 2007/2008 tundra immobilizer
Date Posted: December 05, 2007 at 7:48 AM
Just wondering if anyone out there has found an easy or any location to access the IMO/IMI wire and security light wires in the new tundras. Our shop uses the XK05 bypass for Toyota immobilizer equipped vehicles so any tips on where to find these wires would be great. Thanks
Posted By: KarTuneMan
Date Posted: December 05, 2007 at 9:10 AM
I my self am not really sure what your asking for.... but: The TX is blue, and the RX is lt.green, found at the transponder.
Posted By: tonyberg
Date Posted: December 05, 2007 at 9:24 AM
Unfortunately the XK05 does not use the tx and rx wires...they use the IMO/IMI wires which are typically found at the ECM or the security key ecu, but in a couple different vehicles people have found them elsewhere...thats more the info I am lookin for
Posted By: tedmond
Date Posted: December 05, 2007 at 4:21 PM
i think the wires you are looking for is the wires Kartuneman mentioned. i assume IMO - Immobilizer Output - TX (Transfer) IMI - Immobilizer Input - RX (Receive) dont take my word for it, i would think thats what your looking for.
Posted By: NowYaKnow
Date Posted: December 06, 2007 at 12:50 AM
Pop the center channel cover/speaker and remove the speaker if equipped. You can grab the security light wire right under there. Grab the IMI and IMO wires at the pass kick panel there are a couple connectors there. I usually go off the BACKSIDE of one of the connectors I think it's yellow and a black wire from what I remember, and they change to different colors on the other side of the plug.
Posted By: tedmond
Date Posted: December 06, 2007 at 2:39 PM
maybe u can tell us what the IMI and IMO wires are and what they stand for.
Posted By: throwback2332
Date Posted: February 08, 2008 at 8:10 AM
did you ever find the imo/imi wires at the ecm, the tx/rx won't work. (ive tried) i have the module. thanks for any help
------------- If it's not custom, then it's not you.
Posted By: snotdobbs
Date Posted: February 08, 2008 at 8:24 AM
hes using an xk05 which interfaces with the vehicles immobilizer computer as opposed to like the keyoverall or whatever that utilizes the wiring at the exciter ring (tx,rx) before the immobilizer amplifier... nowyaknow: were the imo;imi wires black for imo and pink for imi, or were they yellow (imo)and light blue(imi)...oh and do you grab positive lights or negative lights in that truck? thanx in advance
Date Posted: February 08, 2008 at 1:41 PM
I know I have the same unit I have i'm trying to get a good location on the imi/imo wires.
I grabed negative at the switch, left of steering harness.
Date Posted: February 08, 2008 at 1:50 PM
2007 tundra pin 29 pink(imo), pin 40 black(imi),ecm conn A24, violet(security light) anybody know extacly where ecm conn A24 is?
Date Posted: February 08, 2008 at 1:57 PM
yah its under thehood up at the firewall on the passenger side of the engine bay
Date Posted: February 09, 2008 at 9:02 PM
Found the wires today
