mariner escape hybrids, remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=99764
Printed Date: May 16, 2024 at 5:19 PM
Topic: mariner escape hybrids, remote start
Posted By: chev104275
Subject: mariner escape hybrids, remote start
Date Posted: December 07, 2007 at 6:34 PM
has anyone done a remote start on a mariner/escape hybrid ? any wiring bypasses or modules i should need l have a customer that wants one thanks in advance Joe
------------- If i Can't Install it I Don't need it Joe
Posted By: perly
Date Posted: December 07, 2007 at 7:02 PM
From what I have been told you should not touch a hybrid. But i could be wrong
Date Posted: December 07, 2007 at 7:04 PM
thats what im being told too but i didnt know if it could be done
Posted By: wrenches
Date Posted: December 07, 2007 at 8:09 PM
What is the point of putting a RS in a Hybrid vehicle anyways. If you're buying a vehicle that is supposed to be "kinder and gentler" to the environment what's the point to leaving it sitting there running for 15 or 20 minutes every day?
------------- Think. It's not illegal yet.
Posted By: mobile1
Date Posted: December 07, 2007 at 10:49 PM
The wiring should be the same for a R/S as a non hybrid. Its ok to work on these vehicles. Don't be scared because its different. I've done starters in a prius and highlander hybrids before and they are fine. Just stay away from the electric motor batteries and the large orange loom. This has a LOT of voltage running through it and would give you a little more than a nasty shock if you shorted it out.
Posted By: NowYaKnow
Date Posted: December 08, 2007 at 12:36 AM
Wiring wise for a starter the escape hybrids are identical.. Obviously no tach wire to be hooked up so if your units tachless mode is iffy, don't bother. As mentioned watch out for the orange loom I believe it is 650VAC..
Date Posted: December 08, 2007 at 6:19 AM
ok um how about when the gas motor shuts off wont the r/s restart it ? its a ford add on remote start made by code alarm
Posted By: mobile1
Date Posted: December 08, 2007 at 9:58 AM
If the remote starter has the ability to shut off engine checking you need to do that too. DEI units can do this I know, but Code, I'm not sure about.
Posted By: vitrox
Date Posted: December 08, 2007 at 5:02 PM
the only difference on the hybrids is that you need a remote starter that doesn't sense the engine. you cannot use voltage sense either. both autostarts we sell have this feature. the compustar pro series and the new scytek units.
