08 ford super duty diesel, remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=99873
Printed Date: May 29, 2024 at 4:04 AM
Topic: 08 ford super duty diesel, remote start
Posted By: saskpuller
Subject: 08 ford super duty diesel, remote start
Date Posted: December 11, 2007 at 12:19 AM
Can anyone tell me where the wait to start wire is on an 08 Ford Super Duty 6.4l Diesel? I set the truck to delay 15sec and customer is telling me that it doesn't start most times if the truck has been sitting for more than a couple hours. I used a pku-f2 bypass. Hoping that isn't the problem as he says it starts no problems when the truck is warm.
Posted By: KarTuneMan
Date Posted: December 11, 2007 at 12:46 AM
How long do you have the starter set to "crank" for, and what did you use for tach?
Posted By: extreme1
Date Posted: December 11, 2007 at 1:45 PM
there is no wait to start wire, 15 seconds is plenty of wait.
tach is tricky, if you have a unit that can do voltage sense use it with max crank time set.
------------- Shaughn Murley
Visions Electronics
Red Deer, Alberta
Posted By: mobilefx
Date Posted: December 11, 2007 at 10:13 PM
i use the small GREEN / WHITE i think it is? for tach which is inside the car running kind or above the ebrake release. its w/ a group of wires that are small and get cut w/ black ends on them. i use that w/ the 18 sec delay my units have and bingo everytime ------------- MOBILE F/X
