94 cherockee door lock
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=99964
Printed Date: June 01, 2024 at 11:35 AM
Topic: 94 cherockee door lock
Posted By: rfwave
Subject: 94 cherockee door lock
Date Posted: December 13, 2007 at 12:40 AM
iam doing a RS & keeyless lock& unlock for this truck . the only one thing is i dont know how to hook up the two wires for power lock/unlock . i knew this is a type A and found the wires , i tested them , they are worked , but my jumper wire with 30 amp burnt out .??? , what the...? scared me ! i need your help .
Posted By: realsnake
Date Posted: December 13, 2007 at 12:43 AM
They are reverse polarity!!! search on the forum for schematic
Date Posted: December 13, 2007 at 12:44 AM
Posted By: rfwave
Date Posted: December 13, 2007 at 8:04 PM
Still don't get it ( not easy to teach me because I am too slow ) can you give me more details?
Posted By: Twelvoltz
Date Posted: December 13, 2007 at 8:44 PM
What is the make and model of the RS you are installing?
The 94 Cherokee uses Positive triggers to activate the factory relays that control the door locks. If you are burning out fuses you are on the wrong wires in the vehicle. In the driver's kick panel you should find a pink/violet for unlock and a ORANGE / violet for lock.
------------- Installer, IT support, and FFL. I need less hobbies.
Posted By: rfwave
Date Posted: December 14, 2007 at 12:41 PM
Autostart AS-1755 . yes i have found these wires (as you stated above) , and i got it right (the two negative output wires from the RS) . -------------
Posted By: moonliter
Date Posted: December 14, 2007 at 1:04 PM
As Twelvoltz mentioned, 94 Cherokee uses Positive triggers, Autostart as1755 provides neg outputs for lock on brown wire & unlock on green wire on the 12 pin wire harness. U need to use 2 relays to convert them to positive outputs for the cherokee. See following diagram
Posted By: rfwave
Date Posted: December 14, 2007 at 3:52 PM
Thank YOU !
