jeffchilcott, where have i been?
Forum Name: Miscellaneous - Off Topic
Forum Discription: Topics that just don't fit anywhere else.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=108463
Printed Date: June 15, 2024 at 1:30 PM
Topic: jeffchilcott, where have i been?
Posted By: jeffchilcott
Subject: jeffchilcott, where have i been?
Date Posted: October 27, 2008 at 3:13 PM
Well I have been on hiatus for about a year now, and slowly starting to come back around.
We made a move from NW missouri to Des Moines Iowa and I continued competing in USACI in which I took home my first world championship. Shortly after I came to realization that I wasnt doing things for the reasons I had started competition.
It was time for a change, I began working on my CRX to begin traying to race it both at the drag strip and Autocross. That means every it of stereo equipment I hav with the exception of some things were sol off and removed from both cars. Last year I was able to run a best of 14.5@96MPH in the 1/4 mile with nothing but factory honda parts. Next year things will get crazy.
My GF meghan has finially finished school after 6+ years and she has started a ful time job, we are also expection our first child in 17 days! Due November 13th!
The 98 civic that we have will be dedicated to daily driving along with autocross duty. It has already recieved a suspension upgrade ith the following. Tokico HP struts, Tein Springs, Civic SI front and rear sway bars, Pic lower control arms in the rear, and ome replaced worn out bushings.
The 98 civic will also see SQ duy when the CRX is done being built. I can only afford to work on one car at a time.
The CRX will be completly stripped down this winter to recieve a fresh coat of paint, all dents and ding pulled, a full cage, and a slew of go fast goodies.
The Ls/Vtec that did reside under the hood is out and everything is being changed. The transmission wil start with a b16 cable trann with a few gear changes and the addition of an afermarket LSD. The motor that will reside under the hood will start with a B20Z block punched out to 2.1 liters. Holding 12.5:1 arias pistons mated to eagle rods and crank. We will be putting a GSR head atop with skunk 2 cams, springs, retainers, and a few other goodies. I will be using 550 cc injectors to feed E85 on a daily basis as compression will check in omewhere around 13.2:1 so pump gas is out of the question. A ported eldelbrock victor X manifold normally used for turbo apps ill fed enough air for this NA application! If all goes ell we intend for the car to run mid to low 11's in the 1/4 mile and still get to see the streets when I feel like taking it out.
As builds on both cars get further along I will post some more pics!
I should be back in the fourms ansering questions to the best of my ability again!
------------- 2009 0-1000 Trunk WR 154.0DB 2009 1001+ Trunk WR
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
Posted By: KarTuneMan
Date Posted: October 29, 2008 at 8:22 PM
World Champ..... that's cool....AND A CHILD, even cooler Congrats on BOTH! Boy, girl... ? -------------
Posted By: the12volt
Date Posted: October 29, 2008 at 8:33 PM
Hey Jeff, glad to see you back. Congratulations on becoming a dad soon. I wouldn't trade being a father for anything in the world, even though my 20 year old is attending LSU and partying heavily at my expense at the moment :| ------------- the12volt • Support the12volt.com
Posted By: i am an idiot
Date Posted: October 29, 2008 at 10:28 PM
Does he need a Job to help keep him out of trouble?
Posted By: stevdart
Date Posted: October 31, 2008 at 8:36 PM
Jeff, nice to let the forum know what you've been up to. I love this stuff.
------------- Build the box so that it performs well in the worst case scenario and, in return, it will reward you at all times.
