95 chevy cavalier tach install
Forum Name: Miscellaneous - Off Topic
Forum Discription: Topics that just don't fit anywhere else.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=23562
Printed Date: May 15, 2024 at 6:57 AM
Topic: 95 chevy cavalier tach install
Posted By: hubbabubbamac
Subject: 95 chevy cavalier tach install
Date Posted: December 28, 2003 at 1:34 AM
hey hows it going? ok i need some help with a tach that i got for my car. it is a sunpro 3.5" tach and i am hooking it up to my 95 chevrolet cavalier 2.2. i need to know where to hook up my tach wire (because i didnt have a tach in my car before) and then i need to know where to hook up the illumination wire to (so that the light turns on in the tach) and then i need to know where to hook the power wire up to.
thanks a lot
andrew
Posted By: Teken
Date Posted: December 28, 2003 at 1:44 AM
Everything you need to know is listed below. Varify all wire colors with a DMM, prior to cutting or integration of the tach unit.
Regards
EVIL Teken . . .
Chevrolet
Cavalier
1995-1995
Remote Starter Wiring Colors and Notes
Function
   Vehicle Color
Location
Start:
   YELLOW
IGNITION SWITCH HARNESS**
Ignition #1:
   PINK
Ignition #2:
   WHITE
Ignition #3:
   N/A
Accessory:
   ORANGE
Brake Light:
   WHITE
(+) AT SWITCH BEHIND DRIVER DASH
Tach Signal:
   PURPLE / WHITE OR WHITE
ELECTRONIC IGNITION MODULE (2.4L) *
Parking Lights:
   BROWN (+)
DRIVER KICK PANEL
Headlights:
   TAN (LO) (+) OR
LIGHT GREEN (HI) AT HEADLIGHT SWITCH
OEM Alarm Disarm:
   N/A
OEM Alarm Arm:
   N/A
Diesel Glow Plug:
Clutch Bypass Wire:
Notes:
   * 2.4L Engine Tach Wire Is WHITE At Powertrain Control Module (PCM). 2.2L Engine Tach Wire Is WHITE At PCM. ** The Z-24 model only is equipped with GM's PASSLOCK Anti-Theft system. See Note #113 - General Motors PASSLOCK Bypass Diagram.
Chevrolet
Cavalier
1995-1995
Alarm and Keyless Entry Wiring Colors and Notes
Function
   Vehicle Color
Location
Constant +12 Volts:
   RED AND RED
IGNITION SWITCH HARN.(BOTH 1 CIRCUIT)
Starter Kill:
   YELLOW
Ignition +12 Volts:
   PINK
Dome Lights/Superv:
   LIGHT GREEN/ BLACK AND
LIGHT BLUE (-) CONVENIENCE CNTR ***
OEM Horn:
   BLACK (-)
STEERING COLUMN HARNESS OR AT RELAY
Power Lock:
   LIGHT BLUE
PASSENGER KICK PANEL, MUST TEST
Power Unlock:
   WHITE
FROM PASSENGER SWITCH ****
Trunk Release:
   N/A
Alarm Input Wire:
Notes:
*** L GREEN/ BLACK (-) Covers Driver Door Only, L BLUE (-) Covers All Other Doors, Diode Isolation Needed Cathode (Band) Side Of Diode Faces Oem Wires. Conv. Center Module Located Behind Driver Dash To Left Of Steering Column. **** Without OEM Keyless, See Note # 203 - Reverse Polarity Door Lock Diagram. With OEM Keyless, See Note #202 - Positive Pulse Door Lock Diagram.
Posted By: hotrodelectric
Date Posted: December 28, 2003 at 9:47 PM
A slight correction if I may. The dash lamp wire on most all N.American-built GM products is gray. This connects the lamp to the instrument rheostat. Be sure to check with a test lamp first.
Date Posted: December 29, 2003 at 10:41 AM
is there any way i could just hook up the 12 volt wire to somewhere in the fuse box, and then hook up the illumination wire up to the illumintaion wire on my deck (the orange one i ran to the fuze box)
