honda civic trunk tightening
Forum Name: Miscellaneous - Off Topic
Forum Discription: Topics that just don't fit anywhere else.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=43473
Printed Date: May 09, 2024 at 10:53 PM
Topic: honda civic trunk tightening
Posted By: aliendisaster
Subject: honda civic trunk tightening
Date Posted: November 21, 2004 at 2:14 PM
i need help tightening the trunk on my 95 honda civic. im getting too much rattle from my 2 12" subs. will tightening the latch down stop the rattle, if so how do i do it? if not what do i need to do? i killed most of the rattle inside the trunk and when i put my weight on the trunk it sounds perfect. i heard about putting weather stripping or silicon along the edge of the trunk, will these work?
Posted By: Ravendarat
Date Posted: November 22, 2004 at 12:01 PM
Bolt on a 30 pound wing, that autta do it. No, but seriously you can try weather stripping or cauking but this is something that everyone seems to struggle with. You can also use dynamat if you can pin point where the rattle is actually comming from. If you have fold down seats you can put latches on the inside that pull the trunk down, I have seen that one before. I think first thing is to pin point exactly what is rattling and then go from there
------------- double-secret reverse-osmosis speaker-cone-induced high-level interference distortion, Its a killer
Posted By: rt2party
Date Posted: December 20, 2004 at 8:35 PM
4 cans of expanding foam sealent in the trunk lid of my 94' Corsica (i sold it or i'd offer pics) also took out the tail lights and used padding to keep them from rattling (took 2 people to re-instll them they were so tight).
Posted By: auex
Date Posted: December 20, 2004 at 10:03 PM
Be real careful doing this, I know people who did this in the winter and the foam never cured. Still leaks to this day. Also if you look at the latch, there should be 2 10mm bolts, loosen them and slide the latch down, adjust and tighten the bolts. ------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: darthness
Date Posted: December 21, 2004 at 8:41 AM
what bout that sound deadning stuff... dynomat (only not dynomat, its wayyy to expensive) and such.
Posted By: misterjimbo
Date Posted: December 22, 2004 at 1:48 PM
expanging foam? a guy did that on a lincoln ls and our the shop had to buy him a new trunk lid, read the side of the can to make sure it doesnt expand ten times its size... oops we got the wrong stuff.
Posted By: gabrielsynn
Date Posted: January 08, 2005 at 9:41 AM
Try a 1" thick layer of egg carton foam. It might not look the best in the world, but it should work...or you could always go the ricer route and find a way to attach hood pins to the trunk....honestly though, you're better off with going all out and buying the Dynamat. Nothing really works better unless you start messing with the latch itself.
Posted By: bluetruck
Date Posted: January 08, 2005 at 3:45 PM
you might try locating exactly what is rattling, is it the tunk lid against the car? or somethign else?
