Body Lift
Forum Name: Miscellaneous - Off Topic
Forum Discription: Topics that just don't fit anywhere else.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=47442
Printed Date: May 19, 2024 at 3:25 PM
Topic: Body Lift
Posted By: daniel2002p
Subject: Body Lift
Date Posted: January 11, 2005 at 11:06 AM
I live in the DFW texas area and was wondering if anyone knows a good place the will do a body lift on my truck (3") for a decent price. also what is the usual price to have a body lift done?
------------- 2005 Toyota Corolla S
1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
Posted By: gcorrea
Date Posted: January 16, 2005 at 9:17 PM
i live in el paso tx and my friend got a 4 inch body lift and wheel combo for $800. i belive the lift alone is going for about $200.
------------- gcorrea
Posted By: Hymer
Date Posted: January 16, 2005 at 10:03 PM
Just curiouse .. why a body lift... It's really BAD for a big truck... I have seen trucks in accidents that the cab, clip, and box are 20 feet from the frame.. In MN we charge 400$ to 500$ for them... (we only do them now in vans that need the floor dropped for a wheelchair lift) but that was also the rate on trucks when we did them...
------------- Tire Proz Stillwater Mn
High End Restyling and Comlete Repair
Posted By: AudioBAHNvlcm
Date Posted: January 19, 2005 at 12:58 AM
Body lifts are GAAAYYY!! they look nasty, just pony up the dough and get a suspension lift.
Date Posted: January 19, 2005 at 11:46 AM
how much does a 3" suspension lift go for?? installed??
1.8L VVT-i I-4
Date Posted: January 19, 2005 at 7:19 PM
on what, 2004 taco?
Posted By: Hymer
Date Posted: January 19, 2005 at 7:52 PM
at least 1200 for the kit it will probably be a 4-5" and another 500 to 1000$ for installation... and keep in mind you may have to buy new rims if you get a spindle lift.. On that yota I would think it would be that style... Not for sure though... It seems to be the way to go with todays IFS systems... Unlike the Trail disaster (master ) lifts for chevs....
Posted By: phidelt85
Date Posted: January 20, 2005 at 3:45 AM
Hymer, what's wrong with Trail Master and what are some pretty good susp. lift rigs out there? I've got an 02 Chevy Z-71 Xcab.
Posted By: Trinity
Date Posted: January 20, 2005 at 9:40 AM
i would run all suspension i wouldnt run a body lift, in my opinion its a cheap way out, theres many different ways i would do it....
Posted By: Hymer
Date Posted: January 27, 2005 at 10:39 PM
Trail disastars are a bracket lift.. tons of parts and just a pain to install, and lots of steering problems... On your truck I would go with the Rancho or a Fabtech.. It's marketed at a 4" but it gives you about 5"+ depending on where you set the torsion bars.. The rancho is a spindal lift (longer steering knuckles) and a FULL cradle that encases the front diff. REAL stabel and it retains all the factory steering geometry. It does however change the track of the truck (front tires have a wider stance than the rear , like the old blazers) but you cant notice it when driving. It goes in in about 10 hrs (if you don't have a clue what your doing) and I think I did one in about 4.5 hrs today with a helper and a hoist. The Fabtech is real similar exept the cradle is 2 pieces. It's easyer to handle and install, but not a whole lot. Both are exeptional lifts... never have ANY problems other than people beating the tar out of their trucks. With both these lifts you do need wheels with a different backspace. The factory ones WILL hit the controle arms, this is due to the enlarged spindle... Any questions, just yell!!
Later
