tachometer doesn't work
Forum Name: Miscellaneous - Off Topic
Forum Discription: Topics that just don't fit anywhere else.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=9361
Printed Date: May 28, 2024 at 7:24 PM
Topic: tachometer doesn't work
Posted By: XdiscontensionX
Subject: tachometer doesn't work
Date Posted: February 11, 2003 at 7:59 AM
i installed new gauge faces this weekend and now my tach needle won't move! i was very careful when moving the needles to slide the new gauges over them. has anyone ever fixed guages before? can anyone give me pointers on how to troubleshoot the problem? should i give up and start looking for gauge clusters at a junkyard? help!
Posted By: Velocity Motors
Date Posted: February 11, 2003 at 12:08 PM
What vehicle did you do this in. The needle for all the gauges as you noticed are very fragile and thin. You might have damaged the needle or bent it slightly and it is hanging up on the new gauges from the backside. Only way to test is to remove the gauge on the RPM pod and test it it works without the new face. If it still does not, you will need a new gauge.
------------- Jeff
