wiring two devices with three switches
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=104500
Printed Date: June 10, 2024 at 7:54 PM
Topic: wiring two devices with three switches
Posted By: still_walkin
Subject: wiring two devices with three switches
Date Posted: May 05, 2008 at 7:58 PM
I have a wiring question and I don't know if I need a relay or not. To make this easier I'm going to name the two devices, device one and device two. Now device one and two are on two different curicits , but on both devices they have one push switch where you can operate each device by itself by pushing the button. What I'm trying to do is put a flip switch(on/off) between the swiches where if I put the flip switch in the on postion I can operate both devices with decive two is that possible or I'm going at it the wrong way
------------- 1993 sdv
Alpine 4x6 6x9 5 1/4 swr-10d4
alpine v60
12.5 VGA flip down
Nettop pc w/10" touch screen
78nova
5-re audio 5x7 ,10" sub &
Xtx-500.5
Posted By: i am an idiot
Date Posted: May 05, 2008 at 8:16 PM
If you put the toggle switch, one terminal going to device one and the other terminal going to device two. With the toggle switch in the on position, and either of the pushbuttons are on, both devices will be on. Depending on the current draw of the mystery devices, you can do this using a third pushbutton switch and a couple diodes. 1 switch for device 1. 1 switch for device 2. and a 3rd switch that will turn both devices on.
Date Posted: May 05, 2008 at 9:05 PM
Well the two devices are a contiental kit and the trunk release on my car they are on different cuircits but are on a 10 amp rating. each of them have a push button switch so you saying if I put a toggle switch between them it will work no problem. I'm thinking that I put the new switch and have the new wires from the switch on the push switch where the devices are connected to the devices. Is that what are you saying. My concern is what if of the push swiches goes out and leaves that curcit on and I use one the other push switch and the toggle is in the on position will that be dangerious
alpine v60
12.5 VGA flip down
78nova
Xtx-500.5
Posted By: hotwaterwizard
Date Posted: May 08, 2008 at 2:16 AM
------------- John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
Date Posted: May 08, 2008 at 3:05 AM
kinda under stand what you are say so the spdt is a toggle and wire that switch on the ends where the devices connect to the ends of the toggle not where the power source is. d is for device adn ts is toggle switch ps is power is switch
alpine v60
12.5 VGA flip down
78nova
Xtx-500.5
Date Posted: May 08, 2008 at 7:21 AM
Your picture will work, Just remember that when the Toggle switch is on, either push button switch will now work both devices.
Date Posted: May 08, 2008 at 9:50 AM
Thanks for your help the toggle switch is a led switch would you suggest using the led function or not
alpine v60
12.5 VGA flip down
78nova
Xtx-500.5
Date Posted: May 08, 2008 at 11:21 PM
Do you want it to light up when it is on?
Date Posted: May 09, 2008 at 12:04 AM
I wanted it to put will that make it more complicated
alpine v60
12.5 VGA flip down
78nova
Xtx-500.5
