trigger with alarm
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=107311
Printed Date: March 17, 2026 at 9:50 AM
Topic: trigger with alarm
Posted By: Matrix7333
Subject: trigger with alarm
Date Posted: September 08, 2008 at 4:41 PM
Hello all, I have a CodeAlarm CA670 and would like to have my strobes flash when the alarm triggers.  I currently have the strobe hooked to a SPST switch, one leg have 12v with 3 amp fuse and the other leg connects to the strobe control wire.
I guess I have to have a relay setup that triggers from the CA670 Siren and latch untill the siren quit receiving its signal/pulse or I disable from remote/unlock door/s?
Can someone help me with a relay setup that could accomplish this or suggest a better way.
Matrix733
Posted By: KPierson
Date Posted: September 10, 2008 at 9:21 AM
You could install a relay on the siren output - I'm not sure if CodeAlarm uses a + or - siren output.
If it is a + output then wire it like this:
Pin 85 - + siren output
Pin 86 - ground
Pin 30 - 12vdc
Pin 87 - siren and strobe output
If it is a - output then wire it like this:
Pin 85 - (-) siren output
Pin 86 - 12vdc
Pin 30 - 12vdc
The only issue here is that when the siren chirps during arm and disarm the strobe will flash.  You may be able to tie the (-) when armed wire in to the mix to elimite the strobe from flashing on disarm.
Kevin Pierson
Date Posted: September 11, 2008 at 8:19 AM
Thanks, will give it a go and let you know.  You just gave me an idea when you mentioned the (-) when armed output, I might be able to find a similar wire when disarm as I have a 06 escalade EXT with this alarm and whenever I unlock the doors it turns all my accerories on, radio ect.
Thanks again
