pulse horn, lights set up for bike
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=114677
Printed Date: May 14, 2024 at 12:46 PM
Topic: pulse horn, lights set up for bike
Posted By: rfhelp
Subject: pulse horn, lights set up for bike
Date Posted: June 25, 2009 at 2:55 AM
I have done a few searches but haven't found an answer.. I have installed a keyfob 12v activator on my bike and I want to add a horn beep and or signal light flash for confirmation of activation. I have an led light to show power on but would like the afore mentioned action as well. Just like a door lock/unlock setup on a car. Is this set up with a relay or circuit board?
Posted By: i am an idiot
Date Posted: June 25, 2009 at 5:50 AM
Does the keyfob 12V activator have any output wires? Can we have a link to the instruction manual for the activator?
Posted By: rfhelp
Date Posted: June 25, 2009 at 1:45 PM
two imput wires (black ground and red 12v in) two output wires (black ground and white 12v out) one green wire (antenna) I didn't get an instalation diagram just writen info on the wires functions
Posted By: spookiestylez
Date Posted: June 25, 2009 at 5:51 PM
what is the model number for the unit you are using? That way we can help you with some searching, and get a half arsed answer or two.
------------- RTFM
Date Posted: June 25, 2009 at 6:12 PM
What exactly does the Activator do? Even if it has no provision for an output, I think that I can do it with 3 relays a couple of capacitors and a couple diodes. If you are willing and able to do a little footwork, I think we can make it work.
------------- Let's Go Brandon Brown. Congratulations on your first Xfinity Series Win. LGBFJB
Posted By: rfhelp
Date Posted: June 25, 2009 at 7:58 PM
all the unit does is turn on and off a 12v source.
Date Posted: June 25, 2009 at 8:05 PM
I have it down to 2 relays, and one capacitor. I will not be able to give you a multiple beep for either. But we can make one of the pulses longer than the other. Interested? ------------- Let's Go Brandon Brown. Congratulations on your first Xfinity Series Win. LGBFJB
Posted By: rfhelp
Date Posted: June 25, 2009 at 11:06 PM
Ok, here is what I came up with. The key fob will powerup the bike, lights and dash. The rocker switch brakes the starter solinoid coil lead. The ground for the starter solinoid is a case ground. Please look at the diagram to see if I am going to burn down the bike with this setup. ahahahahah.,...
Date Posted: June 27, 2009 at 8:02 PM
I wish I could come up with something you could use. If I figure something out, I will let you know. Off to perform the John Cena Trademark move.
Posted By: rfhelp
Date Posted: June 27, 2009 at 9:34 PM
Thanks for the effort. I have installed the above system. No one had replied so I went ahead and installed it. SEems to be working very well. I will continue to try and work out the chirp thing too as I think that would be cool on a bike. This bike is done and on to the next one. https://www..com/watch?v=RDZUgdCNC9c cheers, Rob
Posted By: rfhelp
Date Posted: June 27, 2009 at 9:35 PM
Oh, I see youtube links are not welcome...
Date Posted: June 27, 2009 at 10:06 PM
Wow
Correct Youtube links do not work here.
Nice Canteen, you take her over any sweet jumps?
Posted By: rfhelp
Date Posted: June 28, 2009 at 2:17 AM
Thanks, No jumps. I built that kat for another guy. There are a few more I built and my own kat on my website. www.robwilton.com Now that I have found you dudes, I am very interested in doing something unique for my own ride. NOt sure what that may be yet but something. I thought a remote start would be cool but since these old dogs are manual choke and not fuel infected its a problem when its cold. I have been playing around with the idea of using a reverse camera setup with dual screen monitor for my rear mirrors. One cam on each side connected to my signal switch so when I activate the signal the corresponding camera comes on and gives me the view a mirror would. Also thinking of a motion sensor for blind spot detection. If there is a vehicle in my blind spot an led would light up, but, I am having trouble finding a sensor that has enough range (lets say 15 feet) IF you check katman1260 on youtube, I have an rfid setup on a katana as well on my channel.
Posted By: KPierson
Date Posted: June 28, 2009 at 8:42 AM
If you don't mind adding a circuit board it would be pretty easy to add a beep and light flash output. I have a similar circuit already built (do a youtube search for Electronic Beep). My current system triggers on seperate 12vdv pulses (lock and unlock pulses). I could easily modify it to trigger the "unlock" on the presence of voltage and the "lock" on the absence of voltage. ------------- Kevin Pierson
Posted By: rfhelp
Date Posted: June 28, 2009 at 12:41 PM
No, don't mind at all.
Date Posted: June 28, 2009 at 1:52 PM
Wow
