What type of wiring/fuses for relay?
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=11726
Printed Date: May 03, 2024 at 2:35 AM
Topic: What type of wiring/fuses for relay?
Posted By: 2G Sport
Subject: What type of wiring/fuses for relay?
Date Posted: April 01, 2003 at 8:46 PM
Now that I grasp the relay concept, I would like to know what types of fuses(glass/blade/etc) and what gauge wire do you use when wiring relays and switches(for both a single switch/relay and multiple relays/switches). I would also like to know the method you use to wire a fuse into the + wire. Thanks in advance.
Posted By: djfearny2
Date Posted: April 01, 2003 at 8:53 PM
well you can use any wire. (stranded). now you just have to estimate the draw you will be putting through that relay to determine your best bet on guage wire. the most i have used on a normal 30-40 amp relay was like 12 guage. and that was for high power piaa fog lights with a 30 amp fuse,. now as for fusing goes get a normal fuse holder for blade fuses. and use that. and you dont have to have the fuse connected to the relay it can be in chain from power source to wire to relay. but advice! fuse should be as closes to power source as possible that main reason for using fuses.
------------- Jon
Installer/Help Technician
---coral springs florida---
Posted By: 2G Sport
Date Posted: April 01, 2003 at 9:03 PM
Thanks for the quick reply! I want to make sure I do it right. I am looking to make a "box" to control multiple accessories. I am wanting to have a "master" switch, and a couple of switches to control each accessory separate if I wanted to.
