single relay for amp rack?
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=117730
Printed Date: February 27, 2026 at 2:09 AM
Topic: single relay for amp rack?
Posted By: ghost183
Subject: single relay for amp rack?
Date Posted: November 14, 2009 at 4:28 PM
hey guys, need alittle help here,  i need to wire a momentary ON-OFF=ON switch to a relay, but how do i wire the relay to alternate between polarities? or do i need 2 relays?
the amp rack motor has 2 wires coming out of it, window motor and transmission,  wired normally, spins counter clockwise, and when you filp the +/- , the motor spins in opposite direction
so how do i wire a momentary switch for,   switch held up = rack slides out, switch held down = rack pulls in..
thanks guys
Posted By: howie ll
Date Posted: November 14, 2009 at 4:50 PM
Use a 5 wire window switch from spal, MES etc.
Posted By: i am an idiot
Date Posted: November 14, 2009 at 5:18 PM
I do not know how hard it is to find a spal power window switch.  The following diagram is the same thing as their switch.  The switch is a Double Pole Double Throw Momentary On-Off-On switch.
posted_image
Posted By: howie ll
Date Posted: November 15, 2009 at 3:45 AM
Effectively the same Mr.I The spal switches are 5 terminals inline. Outers are motor wires, next in are the 2 grounds commoned of course to the outers at rest and the centre is your 12v+ feed.
Date Posted: November 15, 2009 at 7:20 AM
Since you asked about relays,   https://www.the12volt.com/installbay/forum_posts.asp~TID~117734~get~last#574028
To wire the switch, you will need a single Pole Double throw momentary switch.  Ground the center leg.  Connect one of the remaining terminals to the wire labeled to 3 wire switch for up.  Connect the last terminal to the wire labeled to 3 wire switch for down.
If you have 2 free aux output channels on your alarm system, it will be very easy to have the rack move with your remote of your alarm.
Posted By: ghost183
Date Posted: November 15, 2009 at 9:22 AM
thats awesome, thanks alot guys
