viper 211hv keyless entry
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=126227
Printed Date: February 18, 2026 at 6:45 PM
Topic: viper 211hv keyless entry
Posted By: nascarguy55
Subject: viper 211hv keyless entry
Date Posted: February 20, 2011 at 10:29 AM
I have a this prduct but having problem getting door locks or any negitive pluses to come out except the progressive door lock wire solides blue i know i have to convert signal to positive for my 98 s10 pickup doorlock and have created the relay setup but whhen i trigger the remote with meter attached i get no readings. any help wouyld be much welcomed. I am including the digram for wires on the 211
   H1/1  ___ RED                                   (+) 12V CONSTANT POWER INPUT
   H1/2  ___ BLUE                             (-) 200 mA SECOND UNLOCK OUTPUT
   H1/3  ___ BLACK/ WHITE-1        INPUT OF DOMELIGHT SUPERVISION RELAY #87
   H1/4  ___ BLACK/ WHITE        OUTPUT OF DOMELIGHT SUPERVISION RELAY #30
   H1/5  ___ GREEN/ BLACK                               LOCK #30 COMMON OUTPUT
   H1/6  ___ WHITE/ BLACK                             LOCK #87 NORMALLY CLOSED
   H1/7  ___ VIOLET/BLACK                      LOCK #87 NORMALLY OPEN (INPUT)
   H1/8  ___ BLUE/BLACK                            UNLOCK #30 COMMON (OUTPUT)
   H1/9  ___ VIOLET                         UNLOCK #87 NORMALLY OPEN (INPUT)
  H1/10  ___ WHITE                             (+/-) PARKING LIGHT FLASH OUTPUT
  H1/11  ___ BLACK                                      (-) CHASSIS GROUND INPUT
  H1/12  ___ BROWN                                           (-) HORN HONK OUTPUT
  H1/13  ___ LT. GREEN/ BLACK                               FACTORY ALARM DISARM
  H1/14  ___ WHITE/ BLUE                   (-) 200 mA CHANNEL 3 VALIDITY OUTPUT
  H1/15  ___ YELLOW                   (+) SWITCHED IGNITION INPUT (ACCESSORY)
  H1/16  ___ ORANGE                    (-) 500 mA GROUND-WHEN-ARMED OUTPUT
  H1/17  ___ BROWN / BLACK                         UNLOCK #87A NORMALLY CLOSED
  H1/18  ___ RED / WHITE                                    (-) OUTPUT OF CHANNEL 2
thank you
Joel Guy
Posted By: tony_g
Date Posted: February 25, 2011 at 4:10 PM
by looking at the install for a 320hv which has a similar style wiring the type of input on both the lock and unlock #87 wires determines the output polarity on h1/5 and h1/8 i.e a + input on h1/7 and h1/9 will give you a + lock/unlock output signal on h1/5 andh1/8 and vice versa for a neg signal to those wires. the 2nd unlock output will give a - output anyway as its controlled seperately from the main lock/unlock wiring. how do you have h1/7 and h1/9 wired at the moment?
