relays and horns
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=136183
Printed Date: April 28, 2024 at 11:57 AM
Topic: relays and horns
Posted By: kel789
Subject: relays and horns
Date Posted: February 27, 2014 at 11:07 PM
I have 2 stock horns. One stock horn will be removed using it as a trigger for an air horn with an added relay to it and powered from the battery. The other will be left alone for added loudness if any. Will this work? Thanks.
Posted By: oldspark
Date Posted: February 28, 2014 at 1:23 AM
It should.
Posted By: harryharris
Date Posted: March 01, 2014 at 2:59 PM
First most modern vehicle horns are already relay driven, check if yours is (underhood fuse/relay box?) if so you won't need a second relay, just up the horn circuit fuse to 20 amps.and wire both horn terminals directly to your air horn compressor.
Secondly, it's extremely unlikely you'll hear the original horn!
------------- Test before boxing up.
Posted By: kel789
Date Posted: March 01, 2014 at 5:58 PM
Yes, there is a horn relay in the car. If I decide to connect to 2 air horn compressors do you think I need to up the fuse to 30 amps?
When you say both horn terminals do you mean just 1 set of a positive and a negative terminals?
I appreciate the help. 1 less step for me.
Date Posted: March 01, 2014 at 6:01 PM
Yes to both of your questions, the relay is good for 30 amps constant, if OEM will provide x 2 for short bursts, such as horns.
Except you never originally mentioned 2 compressors, only one.
Posted By: kel789
Date Posted: March 01, 2014 at 6:30 PM
That is correct. I thought about 2 horn compressors after you mention the stock horn probably won't add any loudness.
Many thanks, you have solve my question. 1 less relay is 1 less possible problem.
Date Posted: March 01, 2014 at 6:33 PM
The db rule, you probably need 4 sets of horns to double the power, the real art is trumpet placement, down and forward with short pipe runs preferably straight, the ideal is the compressor forward of and between the trumpets feeding a short straight pipe run to them.
Posted By: kel789
Date Posted: March 01, 2014 at 7:23 PM
Thanks for the db rule. I got excited with your updated info then I realized that under the hood doesn't really have space for 4 sets of horns. I am leaning toward a horn attached to the compressor that seems to be more compact for the available space. The trumpet horn seems a bit too long to work with and I don't really want to deal with the air hose extending under the hood. I love those train horns that I had watched on youtube.
