domelight supervision
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=136272
Printed Date: May 06, 2024 at 12:46 PM
Topic: domelight supervision
Posted By: asde
Subject: domelight supervision
Date Posted: March 14, 2014 at 3:28 PM
Hay guys im new here
Today i was thinking about domelight supervision when i unlock the car the domelight go on and when i open/close the door the dome light go off, i was reading to do this through 775 relay and some BLACK/ white wire??
I have car Daewoo matiz 98' and he have just one wire from door to domelight and is white and negative (-) so now i'm confused about this how to wire this up to work properly ? Thanks for help!
Posted By: asde
Date Posted: March 14, 2014 at 3:33 PM
Ohh and i forgot to tell i have aftermarket central lock in ! :)
Posted By: harryharris
Date Posted: March 14, 2014 at 4:50 PM
You can get a Velleman kit to do it for you.
------------- Test before boxing up.
Posted By: asde
Date Posted: March 14, 2014 at 4:57 PM
Any link to this kit ?
Date Posted: March 14, 2014 at 5:31 PM
Velleman K3500 5410329035006
Date Posted: March 14, 2014 at 5:34 PM
Couldn't find US but here's the UK version, I believe the company is Belgian.
Here's the link https://www.velleman.co.uk/manuals/k3500.pdf
I would add a relay controlled by the ignition to cut either 12V+ or ground when you turn the key.
