relay sequence switcher
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=137026
Printed Date: March 13, 2026 at 8:14 PM
Topic: relay sequence switcher
Posted By: aaalll7
Subject: relay sequence switcher
Date Posted: July 30, 2014 at 7:23 AM
Hello,
My first post here, I'm working on a project which I think a relay solution could work, my knowledge is limited so hopefully someone will be able to point me in the right direction.
Essentially I am looking for a circuit which is triggered by a PIR which is connected to a sequence of contacts 1, 2, 3, 4...
Each time the PIR is triggered the contact moves on in numerical order.
ie
PIR triggered then contact 1 closes (others open
PIR off
PIR triggers then contact 2 closes (others open)
PIR off
PIR triggers then contact 3 closes (others open)
...etc...
I hope that makes sense!
Thanks in advance for your help.
aaalll
Posted By: oldspark
Date Posted: July 31, 2014 at 7:01 PM
Equivalent to a mechanically interlocked switch... (All off or only one output.)
Tho others like HotWaterWizard may have relay circuits, I prefer using electronics rather than complex relay logic if more than a few relays are involved.
I recall a simple sequenced circuit used as a combination switch that uses SCRs but I can't find any images, nor its original hardcopy.
But I goggled seekic.com circuit which looks pretty good - ie, 2 inverters (1/3 of a 14 pin hex inverter chip) & 3 diodes plus whatever output buffer (transistor, MOSFET; 2ma-30mA relay coil + spike suppressing diode; etc) per momentary switch.
If you require a sequenced version, I could try to find the SCR circuit...
