2009 toyota venza
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=137509
Printed Date: April 27, 2024 at 12:23 PM
Topic: 2009 toyota venza
Posted By: russbm62
Subject: 2009 toyota venza
Date Posted: October 22, 2014 at 9:16 PM
Hello
Need help on how the layout is on hooking a relay for a 2009 Toyota Venza I am installing a seat heater on both front seat.
Posted By: howie ll
Date Posted: October 23, 2014 at 5:07 AM
Your switches, are they POS or NEG output?
Posted By: russbm62
Date Posted: October 23, 2014 at 5:15 AM
Positive output.
Posted By: howie ll
Date Posted: October 23, 2014 at 6:20 AM
Take one standard automotive relay, switch input ONLY via ignition.
Take output to relay 86.
Ground to 85.
12V+ constant fused at whatever amperage the kit suggests to 87.
Output to heater from 30.
Notes:-
You must ONLY feed switches from ignition circuit, either ignition switch, fuse box or heater input. If you don't you will drain your battery plus possibly a fire risk.
One relay per seat.
If the kit has one fuse, say 20 amps, then feed 15 amps to each relay
