neons to alarm
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=13843
Printed Date: May 14, 2024 at 6:28 AM
Topic: neons to alarm
Posted By: Sebastian018
Subject: neons to alarm
Date Posted: May 22, 2003 at 10:47 AM
I have a set of undercar neons that want to hook up to my alarm so that when i push a button on the remote the neons will turn on and then off and how do i connect the relay/
Posted By: KBToys
Date Posted: May 22, 2003 at 12:45 PM
86 = aux wire on alarm
87, 85 = constant 12volt
30 = neon lights
87a = not used
I think that is how you hook it up. Hopefully someone will reply to verify. I hooked up my strobes to do the samething.
Date Posted: May 22, 2003 at 1:43 PM
Ok, I Hope Someone reply to verify.
thanks anyway
Posted By: nighthawk2k
Date Posted: June 14, 2003 at 8:30 AM
Best thing to do is to pickup a DEI 545T Nite Light system and interface it to turn on the neon's. ------------- Tommy
-Clifford/Directed/Alpine-Audio & Security-
New York Installer
Posted By: philaf
Date Posted: June 28, 2003 at 9:42 PM
or build the latched relay setup on this site... doing it like kbtoys said will only turn on lights while holding button down, as soon as you let go, would turn off
Posted By: audiophyle247
Date Posted: July 18, 2003 at 4:23 PM
Why not run a relay off of the alarms Parking light wire. Let the signal that blinks your parking lights, switch the relay on & off. Too simple? I thought I'd put in my 2 cents.
Posted By: hmouta
Date Posted: August 17, 2003 at 2:37 PM
how do u determine the remote button sequencing then? my clifford ag4 alarm has about 6 unassigned channels, about 10 being used by alarm. nighhawk where in ny r u. do u have a shop?
Date Posted: August 18, 2003 at 12:55 PM
i work in a shop. i'm in nassau county on long island. ------------- Tommy
New York Installer
