relay and viper 5706v and roll up module
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=139576
Printed Date: May 03, 2024 at 8:10 PM
Topic: relay and viper 5706v and roll up module
Posted By: gaith
Subject: relay and viper 5706v and roll up module
Date Posted: October 15, 2015 at 1:04 PM
hey guys.
I have 2 questions ..
I want to install module for roll up window and I am already installed security system ( viper 5706 V ) , my question is do I need to connect relay between viper and roll up module or not ? I mean is the module consider as a relay when I connect viper to car window.
my 2nd question do I need a module for roll up window or just viper with relay 5 pin and control by aux in remote ?
thanks
gaith
------------- safety first,be sure before doing any job, and after done it.. Gaith
Posted By: howie ll
Date Posted: October 16, 2015 at 2:51 AM
Direct to module, depends on which make of module.
But normally no relay required depending on car make, model and year.
Posted By: gaith
Date Posted: October 16, 2015 at 12:47 PM
Thx howie II,that's very helpful ...
But what If I adding additional device 516U Talking Vocalarm Module ,do I need any relay\ diode for (siren , ignition, ground ,etc , coz I read somewhere remark says 'when adding more than one accessories the average ground when armed output,the two accessories must be diode isolated' !!! What do these words mean? do I need diode for all ground device ( viper ,roll up module ,516U module ) ???.
thanks .. gaith
Posted By: howie ll
Date Posted: October 16, 2015 at 2:06 PM
Wouldn't know, if you're running two items off the orange GWA at H1, then diode separate, 2 X 1N4004, bands towards the Viper, any more than two you might need a relay.
Posted By: gaith
Date Posted: October 17, 2015 at 2:02 AM
This logically, I am totally agree with you using the two diode separate for two item . But, let's discuss.. why we need relay?? for what and where ??
Thanks ....Gaith
Posted By: howie ll
Date Posted: October 17, 2015 at 6:14 AM
You're right unless you use a latching relay, you'll be drawing on the battery all the time the alarm is on.
The orange has limited current capacity so if you want say a third output for it, e.g. a tilt sensor you'd be better off using one of the aux outputs, link as latch with arm.
